![]() | Home > Faults & Fixes > Front power socket/cigarette lighter socket not working |
| cubbyno9 Member Since: 22 Oct 2010 Location: Stepps Posts: 149
Hi all, the front power socket/cigarette lighter socket isn't working, to be honest it hasn't been for some time and just thought I had better get it fixed. I have checked the fuse and it is fine, any other ideas as to what it might be ? many thanks. 2017 Range Rover Sport HSE |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
Is it possible the centre consuls has been removed at some time and the socket connector not re-connected when consul refitted.
Its no big deal but would like to try and get it back working, will investigate further, ta for reply. 2017 Range Rover Sport HSE |
| TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189
Did you find this problem, mine is doing this.
| redamo Member Since: 13 Oct 2015 Location: Cheshire Posts: 72
Same here, but I think it's corrosion. Light is on. Coincidentally the cubby fridge isn't working either. Checked all fuses, nothing wrong. Need to investigate further.
| CDS Member Since: 21 Sep 2011 Location: Oldham Posts: 25 |
I'd check the fuse, no55 behind the glove box, 15amp |
When I originally checked I went off the fuse layout in the handbook which was F15 - School Boy Error! When I followed the diagram on the back of the glove box (as pointed out by CDS - Clive) the fuse F55 had blown. Replaced it (with a fuse kindly donated by Clive) and all is now good. |
Fresh pair pair of eyes is sometimes all thats needed |
| All times are GMT |
