Home > In Car Electronics > Surround Cameras Retro
the_big_1
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
Hi Guys,
Does anyone know what parts are needed, apart from the cameras etc, to retro fit surround cameras on a 2012 AB?
What do the cameras plug in to?
Post #481933 Tue Dec 08 2015 1:55pm
I have just had a look at L/R parts list and apart from the five cameras (even the reverse cam is different) you would appear to need the camera control module, Tailgate Harness, Front Bumper Harness, Possibly Engine Bay and Main Dash Harness. There is something like Twenty Main Harnesses listed depending on Engine, Sound System and various other options fitted so how on earth you would begin to decide which one you needed I would not have a clue.
Post #481955 Tue Dec 08 2015 7:18pm
the_big_1
Hi Col,
I guess if you can get the wiring diagram for the camera system, there should be extra wiring for things like power and CAN then the video source to the cameras etc. All harness will change just to add these wires. If I could get the wiring diagram for the system, I could work it out.
Post #481956 Tue Dec 08 2015 7:30pm
I would imagine if you take out a short subscription to Topix you should be able to find all the relevant wiring diagrams and download them.
I do have surround camera system and not really sure it's of much use to be honest unless you are off roading. might be different if they all come on automatically when you select reverse or something like that but you have to manually select them via the touch screen.
Post #481957 Tue Dec 08 2015 7:44pm
the_big_1
One thing I did think of was that you can get a universal kit where you can select which cameras come on when then feed it into where the reverse camera is but could not find where the reverse camera is connected or the signal type
Post #481959 Tue Dec 08 2015 7:54pm
I do know on the actual Reverse Camera the Fixed one has a coax cable with a Fakra connector and two terminal pins, on the Surround Camera there is the coax cable and four terminal pins. Unfortunately I would not know where they actually go to from the camera.
On the fixed camera the two terminals are simply 12v supply and earth as I did fit a Facelift A/B spoiler and camera to pre facelift car which I then run through a GVIF unit and navigation computer to the screen
Post #481961 Tue Dec 08 2015 8:13pm
the_big_1
I guess its anologe. Will try to test when I can.
Post #481963 Tue Dec 08 2015 8:17pm
Hi
My mistake just had a look at a couple of spare surround camera's I have and they do not have the coax cable just the four pins. If it helps I can add a couple of pictures of the connectors on rear of the cameras.
Post #481967 Tue Dec 08 2015 8:30pm
the_big_1
That would be great if you could!
Post #481970 Tue Dec 08 2015 8:33pm
PEACHY
If its any use I have a 12MY front bumper wiring loom that has the 2 camera connections on it - a new unused genuine part Whistle 16MY Estoril Blue SVR.............
Post #481972 Tue Dec 08 2015 8:49pm
the_big_1
lol if I can work out how they are wired and if it can then be enabled, might be knocking on your dor lol
Post #481973 Tue Dec 08 2015 8:54pm
Bodsy
Site Sponsor
The my10/11 vehicles has analogue cameras. They changed to digital on 2012 onwards.
The reverse camera may well be analogue still. Just because it has four pins, they are for 12v+, ground, video signal+ and video signal shield.
On the 2014 discovery, it's still analogue if you only have the reverse camera, but I don't know if they fit a digital camera for reverse if you have surround. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #481977 Tue Dec 08 2015 9:23pm
Rear Camera
Front Camera
This Plugs into Rear Camera
This Plugs into the Camera Control Module I think.
Post #481983 Tue Dec 08 2015 9:45pm
the_big_1
Great Stuff!!!
I guess they are all digital when surround as they have the moving lines when surround is fitted.
Post #481994 Wed Dec 09 2015 8:12am
Bodsy
Site Sponsor
I would say so, that reverse camera is a different connector to the standalone reverse camera (which is analogue) Bodsys Brake Bible
See it HERE
Post #481996 Wed Dec 09 2015 9:27am
