Home > Maintenance & Modifications > Compressor bracket replacement
Gilly1
hi, I'm going to change my suspension compressor bracket this weekend (hopefully) I've just been reading on removing and refitting compressor and it said when refitted that the computer needs to be reset, is that buy way of diagnostics?
I was just hoping I could remove, refit, start car go through height settings and hey presto job done.. Laughing
Post #481499 Wed Dec 02 2015 7:59pm
gogsy1956
I did the same on mine, the initial faults on first startup soon cleared,, no problems 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #481509 Wed Dec 02 2015 10:03pm
Lost for Words
Just realised I meant to reply to this the other day. No need for diagnostics unless you're replacing a Hitachi with an AMK. Thumbs Up
Be warned - the top bolt is a PITA to get back in! Mad I found a couple of universal joints and extensions over the top did the trick. Wink Visiting from DISCO3.CO.UK
Post #481617 Fri Dec 04 2015 10:14am
Gilly1
Awesome, thanks a lot, yes did read that top bolt can be a pain, I've also got to pop over to Land Rover to get 3 clips just in case any break when undoing bolts. Thumbs Up
Post #481645 Fri Dec 04 2015 2:19pm
mnk
Definitely worth replacing all three clips for ease regardless of condition of old.
I found using a ring ratchet spanner between the compressor and bracket to reach the top bolt easier. But you will find your best method from trial and error.
Post #481649 Fri Dec 04 2015 3:21pm
garrycol
Australia
I replaced my compressor bracket a while back - no resetting of computers etc was required. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #481682 Sat Dec 05 2015 1:55am
