![]() | Home > Maintenance & Modifications > Replacement disc's & pads |
I would replace the brake pad wear sensors too. One on front, and one on the back. I would recommend inspecting the handbrake and cleaning it up, unless you suspect it needs replacing. |
| Zack17 Member Since: 25 Nov 2015 Location: Shropshire Posts: 18
Thanks ,getting bit confused with disc diameters & relationship to wheel sizes ,I have 20" wheels can you point me up right path ? |
There will be 2 sizes of discs fitted to your RRS, 317mm and 325mm, for non-Brembo brakes. Or 360mm and 350mm rear for those models with Brembo front brakes |
Cheers , now to buy & fit ! |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025
Try Advanced Factors for your brake bits - forum sponsor |
Hi DrRob , thanks for the tip ,just ordered & had great deal brembo front/rear kits plus 5% discount at checkout ! ACE
| All times are GMT |
