Home > General > Fbh
Ned
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Fuji White
Fbh
Hi guys go my fbh going by the remote and thanks all those you helped on that, problem now is there is no heat😂 But the fbh works, any ideal what's going on please .
Post #480754 Mon Nov 23 2015 5:08pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
You need to get it checked by a garage with diagnostics, mine wasn't working it turned out to be the FBH fuel pump, this showed once it was plugged in to the computer. Thumbs Up
Post #480762 Mon Nov 23 2015 6:19pm
Ned
Thanks I have the bt lld diagnostic tool can I use this to fine the problem?
Post #480763 Mon Nov 23 2015 6:24pm
gary3306
England 2013 Range Rover Sport SDV6 Autobiography Fuji White
PM Bodsy (Ian), he will tell you how to go on with the IID tool to check your FBH
Post #480765 Mon Nov 23 2015 7:23pm
fkarim
Just plug the IIDTool in, connect the phone/tablet using BT, go to Read Faults, confirm the prompt to read faults. It will scan all the ECUs it recognises and list any faults. You can also perform certain tests on the FBH, fire it up on demand and carry out maintenance tasks like fuel priming using the service/test menu of the IIDTool. I don't remember the exact names of the menu options but they are self-explanatory.
Btw for remote/timed heating to come on I believe you need to leave the climate control on Auto and set the temperature reasonably warm, say 20 deg C. I am not 100% sure if it is a requirement because my CC is always in Auto mode with aircon anyway.
The outside temperature also needs to be fairly low otherwise it just vents the car by turning the fan on with no heat (or cooling). It has been sufficiently cold over the last few days so I doubt this will be the reason though. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory
Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond
Post #480767 Mon Nov 23 2015 7:52pm
Ned
Fkarim thanks so much your really helpful I connected my IID tool up as you said and test the Fbh and it fired up 👍😃 Reading thewebasto T91 remote manual do I need to teach the remote do anything as I can't understand it inm a thickho when it comes to that sort of thing thanks for your time.
Post #480772 Mon Nov 23 2015 8:50pm
Bodsy
Site Sponsor
If the car has just been running, or the car is already he, then sometimes it will just run the fan and not the FBH as it doesn't think it needs to.
Additionally, if you stop running it on the remote, then start it again on the remote 30 seconds later, it will then sometimes work.
But if just running from cold, then it should work fine. Thumbs Up
The remote is flashing green every 2seconds or so when you press it on? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #480773 Mon Nov 23 2015 9:04pm
fkarim
Have you already followed Bodsy's instruction to pair the remote on your other thread: http://www.rrsport.co.uk/forum/post478858.html#478858 ? Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Post #480775 Mon Nov 23 2015 9:07pm
Ned
Yer followed instructions by the T will repair the remote in the morning thanks for your rely.
Post #480778 Mon Nov 23 2015 9:31pm
davebarton1
England 2013 Range Rover Sport 3.0 TDV6 Autobiography Alaska White
Help
Hi All,
This is my firts post, i have a rrs 2015 autobiography and was hoping that i would be able to activate my timed climate. when ive asked my dealership they have give me no help what so ever.
Does any body know how or if i could activate the timed climate.
Thanks in advance.
Post #481221 Sun Nov 29 2015 9:29pm
Bodsy
Site Sponsor
Thumbs Up Bodsys Brake Bible
See it HERE
Post #481233 Sun Nov 29 2015 10:23pm
