![]() | Home > Technical > Heated rear window |
Panavia man Member Since: 27 Oct 2015 Location: North west Posts: 94 ![]() ![]() ![]() |
Sorry that's rear screen! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9112 ![]() ![]() ![]() |
Could well be the connector plug in the rear spoiler. It corrodes and you lose the rear screen.
Cheers- is it easy to get at? |
It's not too bad to get at. I found the actual connector was a pig to open up. 2012 SDV6 - it's missing a couple of cylinders
Ok cheers will have a go! |
Fighter3d Member Since: 28 Feb 2015 Location: Martina franca Posts: 44 ![]() ![]() ![]() |
Hi my rear screen heater does not work properly some wires does not work
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
If the wires are visibly broken you can't do anything other than fit a new rear screen which is around £650, your insurance company may pay for it under your glass cover. |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 ![]() ![]() ![]() |
If you don't want to spring for a new screen, you can get filament repair kit at auto parts store that you paint over the gap with and try that ...cheap fix. |
Thanks for all the advice - will report back! |
