Message the other day stating
"Battery low"
Now a few days later I have "restricted performance" triangle. I assume they may be related IE low charge is causing the message
How do I charge my battery please?
Thanks
Andy2006 RRS Supercharged 4.2 HST muthuaflecka!
Sat Nov 21 2015 7:11am
Frax
I would check your alternator charge voltage first, Start her up and put a volt meter on the positive and negative battery poles, you should get about 14v if it is not reading at least 13v your alternator requires changing.
To charge the battery just connect the charger, red clip to positive and black to negative.
Low power will give you all sorts of problems.Lot of Landcruisers now sold
Audi TT 240 Sport now sold for.
RRS 2.7 HSE Now sold for.
RRS Autoibiography 2012
Defender 300tdi 90
Just to add here, for a facelift vehicle, it is essential that the negative lead is not connected to the battery terminal - so the Battery Monitoring System (BMS) will see the charge. Any ground point will do fine. Visiting from DISCO3.CO.UK
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
