Home > General (L494) > Locking Rear Diff (Full Partial)
R444SPT
Just had cause to use the "Terrain Response 2" and placed it in grass / gravel / snow - I also used the touchscreen and went into the 4X4 options and showed the differentials and suspension high / front wheel location.
Interesting on pulling away - the rear differential shows a partial lock of 2/3 on one screen and a partial lock of 1/3 on another screen.
Perhaps it was at 50% and just confused as it only seems to support
Off / 33 / 66 / On
& yes I realise it is petty, but surely two screens showing the same information - should show the same information ?
Attention to detail and all that.. Whistle Cool
Post #480508 Fri Nov 20 2015 3:41pm
Is this showing on one screen or did you swap between screens to see the two values? 2012 SDV6 - it's missing a couple of cylinders
Post #480539 Fri Nov 20 2015 10:09pm
R444SPT
So screen 1 is the centre display of the LCD dash.
screen 2 is the infotainment screen.
Both operate at the same time, but show different levels of lock, for the same differential, in this case the rear, with screen 1 always showing less lock than screen 2.
Just saying Whistle
Post #480543 Fri Nov 20 2015 10:40pm
