Home > Maintenance & Modifications > Rear anti roll bar
Gilly1
Rear anti roll bar
hi all, I was hoping to change rear anti roll bar bushes/rubbers today 2005 without ACE. unfortunately I got stumped at the first hurdle, Big Cry I was un doing the first bolt of roll bar bush clamp and it was going good until I got approx half way undoing it and it started going really tight, so much so I was thinking if I continue the bolt is probably going to snap, So done back up and gave up. any advice will be very welcomed, shall I just keep at it with force, shall I soak it with wd40 or shall I heat the bolt, Mr. Green
Post #480028 Mon Nov 16 2015 6:05pm
Disco_Mikey
Soak it with WD40, and work it in and out. Whatever you do, don't snap the bolts Big Cry
Post #480051 Mon Nov 16 2015 7:42pm
Gilly1
Hi mikey, yes snapping it was my worry, I'll give it another go weekend and as you say I'll give it good soaking and take my time, (talk to the big man in the sky wile doing it Bow down )ha.
Post #480079 Mon Nov 16 2015 10:45pm
