![]() | Home > Technical > Steering lumpy |
Lower steering column |
| monty19 Member Since: 12 Mar 2014 Location: boro Posts: 323
as bodsy said wd 40 sorted mine out last winter and its been fine ever since |
| oneworld1967 Member Since: 30 Apr 2014 Location: Lincoln Posts: 3
Hi Bodsy
Now you've lubed the crud away, spray it liberally with grease |
| tone 123 Member Since: 18 Dec 2014 Location: northeast Posts: 36
had the same problem as oneworld1967. WD40 then some GT85 good as gold thanks lads. |
| Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380
Can i ask, where do we find this UJ is it under the bonnet or underneath the front of the beast ?? I would like to check mine to see if its covered in whatever |
HI. you will find the UJ under the bonnet. its part of the bottom steering column. and joins onto the rack. the best way to get at it is by taking the bash plate of underneath held on by 10 bolts. |
