Home > Technical > Keyfob unlocking problem
RobH69
2008 Range Rover Sport TDV8 HSE Java Black
Hi guys,
Having an issue with my range rover, basically the two key fobs are not working to lock/unlock intermittently. I have been searching for someone with the same issue but can't make sense of it. From what I gather when the battery is low it should show as a warning on the dash, which it isn't. Also the fact that the two are the same I am guessing that it is an issue with the receiver or whatever it communicates with.
Any ideas or help greatly appreciated.
Thanks
Rob
Post #479946 Sun Nov 15 2015 8:52pm
Bodsy
Site Sponsor
There's three wires in the passenger side that all terminate together and the join corrodes.
Find the wires, and rejoin them.
The wires are green and white and look a little something like this.
 Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #479949 Sun Nov 15 2015 10:10pm
RobH69
thanks for the reply, have it all stripped but having trouble finding where the wires join
Post #479952 Sun Nov 15 2015 10:41pm
Bodsy
Site Sponsor
The wires could be anywhere along that big bunch of wires, often buried in the middle of the bunch, occasionally tucked away even further up wrapped in the bigger plastic under the metal 'bridge'
It's often easier to take the front seat out. Bodsys Brake Bible
See it HERE
Post #479956 Sun Nov 15 2015 11:09pm
RobH69
ya it's a mess of wires, I will have to leave it until daylight tomorrow as it's raining now. On the plus side the fob is working now whether it's a coincidence or mee pulling at the wires. Thanks for the help!
Post #479959 Sun Nov 15 2015 11:13pm
