Home > Technical > the engine stops running as soon as the jump leads are off
tbksuk
United Kingdom 2009 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
hi all
the battery on my range was flat after being parked for 2 weeks in a garage, and after jump starting it and driving it for a about 25 miles it just stopped on the motorway, and it repeated a few times. now if i jump start, it will start but as soon as i take the jump leads off it will stop.
can some one tell me if this would be the battery or alternator or anything else?
thanks in advance
Post #479778 Sat Nov 14 2015 12:56pm
Disco_Mikey
You need to attempt to charge the battery with a proper charger, to see if the battery is faulty first Thumbs Up
A 25 mile drive will not charge it
Post #479779 Sat Nov 14 2015 12:59pm
Lost for Words
What voltages are you getting (alternator and battery)? Visiting from DISCO3.CO.UK
Post #479785 Sat Nov 14 2015 2:17pm
Frax
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Had this on a Dodge Ram, battery was U/S but do have a look and see what the charge voltage is Lot of Landcruisers now sold
Audi TT 240 Sport now sold for.
RRS 2.7 HSE Now sold for.
RRS Autoibiography 2012
Defender 300tdi 90
Post #479802 Sat Nov 14 2015 5:29pm
gary3306
England 2013 Range Rover Sport SDV6 Autobiography Fuji White
You can only check the alternator output once it runs on its own. Checking the output whilst the casualty vehicle has jump leads attached from a donor vehicle will give you a false reading as it is receiving input from the donor vehicle alternator. The first thing to do is put the battery on a slow trickle charge off the vehicle for 24 hours, then refit and check charge rate. If you are getting a decent output from the alternator, and I always work on seeing at least 13.5v, then you are looking at a new battery.
Post #479803 Sat Nov 14 2015 5:41pm
tbksuk
thanks everyone. so if i leave the engine running for a couple of hours leaving the leads still connected to the donar vehicle, will not charge the battery?
Post #479882 Sun Nov 15 2015 11:07am
Lost for Words
Not really, no, as the alternators are still having to power the vehicles. You need a proper charger. Thumbs Up Visiting from DISCO3.CO.UK
Post #479885 Sun Nov 15 2015 11:10am
tbksuk
lost for words, thanks buddy.
i might sound abit .... Smile but what do you exactly mean by a proper charger?
Post #479899 Sun Nov 15 2015 12:38pm
Lost for Words
You make a good point really! When I say "proper charger" what I really mean is "charger". Laughing
A smart charger like a CTEK would be ideal though, and a good investment for a RRS owner. Thumbs Up Visiting from DISCO3.CO.UK
Post #479900 Sun Nov 15 2015 12:53pm
tbksuk
got ya Wink
cheers
Post #479917 Sun Nov 15 2015 4:02pm
gary3306
Yes don't leave the donor vehicle connected with both vehicles running as it won't be a good outcome for either vehicle. As said, take it off the vehicle and charge it properly on a trickle for 24hours. You can't really move forward until you have done this. Unless of course you just bite the bullet and buy a new battery; which I suspect you may have to do anyway.
Post #479920 Sun Nov 15 2015 4:35pm
tbksuk
i jump started and left the engine running for a couple of hours... it starts now without any jump start now, but still scared to take it for a spin incase it just stops on me while driving, as it did once last week.
i guess i would take your advice and give it a proper charge for a good 24 hours. cheers
Post #479931 Sun Nov 15 2015 6:08pm
Buckster
I have a CTEK MXS 5.0 charger and they are a top bit of kit, if you have tow bar electrics you can buy a plug in adapter from Disco 3.
If I'm not using the Rangie for a while I just run the lead out the garage and plug into the tow bar socket so I can leave the car secure without having the bonnet up to charge. A very worthwhile investment, they also do full discharge and battery reconditioning which is recommended once a year on any battery Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #479934 Sun Nov 15 2015 6:28pm
gary3306
If you were driving and it died, then that points to a faulty alternator. The battery is only there as a means to start the vehicle. Once it has started then the alternator runs all electrics as well as putting a charge back in the battery for your next start-up. If the alternator isn't grafting, the battery power will be used until such a point where it goes flat and you grind to a halt. If you can start it now, then get a test meter and put it on the '20v' range and with the vehicle running put the leads from the meter onto the pos and neg terminals on the battery. You should see at least 13.5 volts. Any less and the alternator isn't really up to scratch. If your battery is quite old now, this may have damaged and it may not hold a charge anymore, but don't buy a new battery without checking Alt output first as you will eventually just grind to a halt again if the Alt is goosed. Good luck
Post #479935 Sun Nov 15 2015 6:40pm
tbksuk
thank you all. i appreciate it.
Post #480083 Mon Nov 16 2015 11:07pm
