| RRSPORT.CO.UK | ||
|  | Home > Faults & Fixes > Engine fault Special programs off appears when accelerating |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003      | Fault codes need to be read, I would change the fuel filter first though.. 2008 G4 RRSport TDV8 current
|  Sat Nov 14 2015 10:51pm |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477    | ^^^^ +1. Fuel filter is a likely culprit.  | ||
|  Sun Nov 15 2015 10:07am |
| Wogger03 Member Since: 17 Mar 2016 Location: Nottinghamshire Posts: 7  | I have just bought a 55 plate rrs and I'm having the exact same issues, iv got the car booked in next week to be checked over by a Landrover specialist. Not a great start to Landrover ownership! I knew I'd have issues just thought I'd go longer then a day! | ||
|  Thu Mar 17 2016 11:01pm |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003      | Take it back to ware you got it from and let them sort it.. 2008 G4 RRSport TDV8 current
|  Thu Mar 17 2016 11:21pm |
| Wogger03 Member Since: 17 Mar 2016 Location: Nottinghamshire Posts: 7  | That's the plan, it only does it after accelerating hard a couple of times, then special programs message pings up along with engine fault   | ||
|  Fri Mar 18 2016 6:27am |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003      | As mension end above try a new fuel filter before anything else.. 2008 G4 RRSport TDV8 current
|  Fri Mar 18 2016 12:55pm |
| Wogger03 Member Since: 17 Mar 2016 Location: Nottinghamshire Posts: 7  | Cheers mate, I have a feeling I'll be using this forum a lot haha | ||
|  Fri Mar 18 2016 1:13pm |
| TenBob Member Since: 01 Nov 2010 Location: North Posts: 138      | I had this happen on my TDV8. Turned out to be the fuel pump failing, which somehow managed to deposit metallic particles in the fuel system. LR dealer replaced the fuel system (yep, the lot) under warranty, thankfully. I've never heard of this happening before, and neither had the dealer, so it's rare. Fingers crossed for you it's the fuel filter. TDV6 2010 HSE
|  Fri Mar 18 2016 2:01pm |
| Wogger03 Member Since: 17 Mar 2016 Location: Nottinghamshire Posts: 7  | Let's hope so! The car had been stood a couple of weeks on the dealers yard and was very low on fuel when I collected it so with a bit of luck new filter, fresh fuel and a fuel flush might work. Rang the dealer today and he's said try it, he's going to refund me the money and if not he's going to take it back to have a look! | ||
|  Fri Mar 18 2016 2:11pm |
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594      | If they don't fix it I would give them the car back and walk away. These cars are decked out with electronics. Bushes, swing arms, bearings etc. are all (relatively) easy to replace, if you get a motor with bad electrics you may as well give up. | ||
|  Fri Mar 18 2016 4:03pm |
| Donithediver Member Since: 24 Jan 2016 Location: Glasgow Posts: 13      | Ah finally found someone with at least a suggestion. My 2006 sport has had this issue since purchased privately..I took in to Landrover they told me egr faulty on both sides. One 0% one 40% efficient quoted me 1000 to fix but would promise a fix. I got home popped bonnet and egr have been blanked previously. So confused.. exact same syptoms same place everyday.. One thing I have noticed is I'm getting quite a bit of black smoke when sinking the welly. But hey it does no harm to change fuel filter regardless.. brilliant site thanks | ||
|  Mon Mar 21 2016 11:51pm |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003      | If no luck with the fuel filter would be checking inter cooler hoses next for both splits and collapsing.. 2008 G4 RRSport TDV8 current
|  Tue Mar 22 2016 12:31am |
| hard2beat2014 Member Since: 14 Jun 2014 Location: cambridge Posts: 63      | get it code read before you do anything , my guess would be split intercooler or split intercooler hose | ||
|  Tue Mar 22 2016 3:53pm |
| Wogger03 Member Since: 17 Mar 2016 Location: Nottinghamshire Posts: 7  | Thanks for the advice guys, the Landrover blokes coming at the end of next week so hopefully he will let me know (cam belts being done to) if it's terminal and / or he finds any major issues the cars going back! Hope it's just some age related niggles and a simple fix love the car already | ||
|  Tue Mar 22 2016 8:51pm |
| Posting Rules
 the lights on the special programs dial turn off then it drives fine
