Home > Technical > Automatic gearbox makes noise like manual gearbox!
xoxoLisa-Marie
Sorry if i've posted in the wrong place but obviously mods can move to the correct place.
I'm not really good at explaining but this is the only way i can describe what my Range Rover does. It doesn't happen all the time, for example if i'm driving slow but then accelerate it makes a noise like a manual would when you don't change gears at the right time. I took it for a service today and they said they couldn't find a fault with it. Does anyone know what it could be?
Post #479604 Thu Nov 12 2015 6:11pm
Camelrock
Hi to be honest what your describing doesn't make a lot of sense. I would take it to a main dealer or good indi and go out with the tech and show them what you mean .. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #479659 Thu Nov 12 2015 11:22pm
xoxoLisa-Marie
I know it's very difficult to explain and it can only be shown if driven which they did when they tested it but like i said they couldn't find a fault. It kind of sounds like its revving up and doesn't shift as quick when accelerate, but this never happened before. Only just recently. I did take it to Land Rover so i'm all out of ideas!
Post #479664 Fri Nov 13 2015 12:09am
Bodsy
Site Sponsor
Where abouts in the country are you? If you fill in your profile, it's not because we're nosey (although some are Wink ) it's because someone near you might be able to help or at least compare vehicle sounds. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #479668 Fri Nov 13 2015 12:55am
xoxoLisa-Marie
Haha no it's just my dumb sense of humour. So i wrote that to be cheeky. I'm in Staffordshire UK Smile
Post #479670 Fri Nov 13 2015 3:21am
Disco_Mikey
Is it loosing drive when the fault happens?
Next time it does it, check the dash to see if the little "D" has disappeared from the speedo Thumbs Up
It could be a seized gear lever pivot
Post #479674 Fri Nov 13 2015 7:48am
