![]() | Home > In Car Electronics > Car resetting |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025 ![]() ![]() |
Take it to a land rover specialist independent who know these motors like the back of their hand.....they are complex motors that need guys with experience |
Mitchell Hill Member Since: 12 Nov 2015 Location: Birmingham Posts: 3 ![]() ![]() ![]() |
Couldn't agree more! Just wondered if anyone else had had the same problem |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
I had a similar issue and it was one of the battery connections not on tight enough. Sounds like you've checked test though. |
Ill double check them. I'm at a point where I'll try anything |
As above sounds like a bad battery connection. Make sure you check both ends of the battery leads though..also check starter connections and any earthed you can find.. 2008 G4 RRSport TDV8 current
Be sure to check the alternator voltage while you're there too. |
