![]() | Home > Technical > Break and gear shift click when applying the break |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
I have this as well but mine is only in neutral. As you say press brake pedal up and down click click from the gear stick |
Shift interlock solenoid. I'd say it's normal to hear it - perhaps since the brake switch has been changed, it happens more readily so you're now noticing it? |
Lee69 Member Since: 15 Sep 2015 Location: Liverpool Posts: 24 ![]() ![]() ![]() |
thanks for getting back
Since the power to the solenoid is provided by the Transmission Control Module (TCM), it seems unlikely that it would actually make it louder, but the ECUs are significantly affected by the brake switch - not least the TCM - so perhaps it could be down to the behaviour of the ECU. Visiting from DISCO3.CO.UK
sorry for being thick but what does that mean in English haha
It just means maybe the signal provided from the brake switch has been affecting the manner in which power is provided to the solenoid.
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 741 ![]() ![]() ![]() |
O/T: What is this app? Regards etc.,
IID BT |
I think I will buy a new one an see how it goes.
