Home > Technical > MY2013 RRS 3.0 litre turbo fault P1247-00
Page 1 of 3 123>
Minshy
Driving home yesterday and red triangle come up on dash, restricted performance on display.
Had Land Rover assist out to it this morning, he said its either actuator or turbo blown, car has covered 22k.
Waiting for landrover to sort me out a courtesy car.
Not a happy bunny
Is this a common issue
Post #479504 Wed Nov 11 2015 8:03pm
scrumps
Happened to me three times on my 13.5MY HSE Black.
LRA called out each time - then passed to supplying dealer.
1st time tried WD40 on the CSOV valve (turbo changeover valve)
2nd time changed the entire CSOV valve.
3rd time car had extensive diagnostics directed by the factory and the primary turbo was U/s. Body off and new turbo!
Tech checked old and new turbo's side by side on bench and original turbo actator arm was in the wrong position! We reckon the turbo was hitting the end-stop and causing the fault code and restricted performance when full boost was demanded (heavy rIght foot) as fault clears if car left for 30 mins to do a full shut down/reset.
On the plus side, fuel consumption has reduced by about 10-15% and mid range the acceleration now is stunning. Performance nearly made me reconsider ordering a new L494 AB for March 16 delivery. Still puts a smile on my face cross-country.
Been faultless for 14 months since turbo change!
Scrumps. Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #479522 Wed Nov 11 2015 10:48pm
Minshy
Thanks for the info,
Interesting times ahead then
Post #479525 Wed Nov 11 2015 11:12pm
Minshy
Day 3 and still no car been sorted.
I understand Land Rover used to use enterprise car hire for courtesy vehicles with assist issues.
This has now changed and they now organise internally, so frustrating when all I want is my car sorting.
If not sorted tomorrow will be ringing customer services to raise a complaint.
Post #479631 Thu Nov 12 2015 8:47pm
Buckster
Day 3! Shocked I would be kicking off by now! Big Cry 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #479643 Thu Nov 12 2015 9:50pm
Minshy
I will be tomorrow morning,
Just plain rude, even if they haven't found me a car to use a call to update would have been nice.
Post #479649 Thu Nov 12 2015 10:18pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
TADT (dealer not the car), it appears to be a necessary qualification to be a LR dealer
Re the car, mine (2013 model) has had the restricted performance problem on long trips for the last 6 months. Here's the attempts at rectifying it
1. Changed clips to hold hoses tighter
2. Diagnosed faulty turbo
3. Take car in to have new turbo fitted, came out only with a new CSOV valve.
4. New manifold air valve fitted
5. Going in next week for extensive diagnostics directed by LR after me paying the Dealership Principal a visit to vent my views on the inefficiency of his dealership following 3 days of failed returned calls from his staff to discuss the next step. I also made sure he was aware of the deplorable service I have had from this dealership over the past 6 months which I detailed in a previous thread.
Here's what I was told:
Although a possible fault with the turbo has previously been diagnosed LR will not authorise a replacement until other remedies have been tried (hence 3 & 4 above). It is a known fault and in some cases replacing the turbo has not solved the problem even though the fault code suggests the turbo. The last one they did turned out to be a fault on one of the looms.
So car goes in next week for extensive diagnostics which I am told could take up to 2-3 weeks since everything they do will be directed remotely by LR and after completing each stage it will be tested & results reported back to LR. Courtesy car will be a Discovery Sport.
My car will be changed next year and the outcome of this latest event will determine if a LR even makes it on to the list of possible replacements
Post #479680 Fri Nov 13 2015 10:06am
Minshy
car now sorted, a discovery sport on its way to dealers, all i need to do is get the car there
wish me luck,
Steve
Post #479681 Fri Nov 13 2015 10:07am
Minshy
Paul,
be interested on how this develops, not holding much hope of a quick resolution judging by you two guys have said.
Steve
Post #479684 Fri Nov 13 2015 10:10am
Paulcp
Will let you know, car goes in this Friday so not expecting it back for a while
Post #480062 Mon Nov 16 2015 8:22pm
Minshy
Had word back from dealer.
Primary turbo is knackered, a new one on order.
Will let me know lead time by the end of the week.
Oh Dear
Post #480302 Wed Nov 18 2015 6:15pm
scrumps
Minshy,
Sorry to hear that - hopefully you'll get the same benefit I did.
Would be interesting to see if your actuator arm is mis-aligned too. Might be worth asking your dealer to do a comparison between old & new during the replacement.
My car was built Jan 13 - I wonder if there are a batch of dodgy turbo's around?
Scrumps Somerset - Where the apples do grow and the cider do flow!
Post #480305 Wed Nov 18 2015 6:46pm
Minshy
Hi mate,
Let's hope so, it might get rid of the flat spot I sometimes suffer when setting off.
I am going to ask the question about the actuator when they update me at the end of the week.
I am not too happy about the discovery sport they gave given me, it's like driving a bloody go-kart. Laughing
Mine was registered March 2013, not sure on build date. I assume it is built into chassis number but not surge
Steve
Post #480321 Wed Nov 18 2015 7:52pm
scrumps
Hi mate,
Mine was registered 1st March too -hence the engines could be a close batch match.
Post #480335 Wed Nov 18 2015 9:00pm
Minshy
If there was a faulty batch I bet we would never find out
Post #480338 Wed Nov 18 2015 9:10pm
Page 1 of 3 123>
