![]() | Home > Faults & Fixes > rain sensor not working |
| tone 123 Member Since: 18 Dec 2014 Location: northeast Posts: 36
hi. do you have the indicator stalk up one all the time. |
| gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 212
As Tone says, you must move the stalk to position 1 and leave it there for them to operate automatically. If your lights work, there isn't going to be anything wrong with the sensor. What I will say is if your windscreen is minging dirty, that hinders the sensor performance. |
| sport2007 Member Since: 10 Feb 2015 Location: bt67 Posts: 41
Range rover sport always clean no issue with dirt or muck covering the sensor . I have had the stalk at the correct position at 1 but no joy, with the lights working its not the sensor is that correct?
have a look from the outside, to see if the sensor is ok. it should be blue purple clear with no blisters misty or white. |
ok I will have a look tomorrow and come back maybe get a few photos.
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003
If as you say the auto lights are working then the sensor is ok and your wipers are working in normal and fast speeds then sounds like a faulty switch when position 1.
hi there
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9157
The rain sensitive wipers can be disabled by altering the CCF. I've done this on my own TDV8 because I hate rain sensitive wipers. If the system has never worked since you bought the vehicle, get the CCF read by someone with a suitable plug-in system. I did mine with my IID Tool. 2012 SDV6 - it's missing a couple of cylinders
hi such a long time but what does ccf mean |
| All times are GMT |
