![]() | Home > Technical > Tow bar - Thule EuroClassic G6 928 |
I have one similar to what you are looking at, mine is the Land Rover one but made by Thule. Never had any problems using it with a detachable tow bar and can't see why it would not be suitable. Great bit of kit and tilts with bikes on to allow boot access. Just taken this sat at the ferry port |
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 ![]() ![]() |
Did (whoever it was) explain why it would not be suitable for the detachable tow bar?
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 ![]() ![]() ![]() |
Thanks Buckster for the heads-up. I've changed my mind on the model I'm going for the Thule VeloCompact 925 I think will be similar to yours - which by the way looks cracking on the back of your RRS |
I have a big motorcycle chain lock that I attach to the rack and through the bikes via the recovery point on the back of the crossmember to prevent the scum from nicking the rack. A worthwhile investment as I don't fully trust the lock on rack to towbar |
Sounds like a great idea - Thanks |
Woppyman Member Since: 08 Jul 2015 Location: England Posts: 68 ![]() ![]() ![]() |
I think I may know the problem. My Thule bike carrier when mounted on detachable towbar is very close to exhaust. This has melted all the plastic wheel retainers. Maybe other tow bars have height adjustment to get higher than exhaust pipes?
As said above, shouldn't be an issue.
