![]() | Home > Technical > Fbh remote. |
| ilard Member Since: 20 Aug 2010 Location: London Posts: 975
I think you will need to program the fob. Hopefully someone has accurate instructions! But it goes along the lines of disconnecting power from the axillary heater's receiver, and then when you power it again holding one of the key fob buttons for a few seconds.
| Ned Member Since: 25 Jul 2015 Location: London Posts: 100
Thanks ilard there's a post on the forum I will follow thanks for the reply. |
| myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433
I seem to recall that it needs to be the remote type that's oval, almost egg shaped when looking down on it, not the one that's flatter along the bottom edge. Hope this helps. |
Yes, remove Fuse 2 in the engine bay fuse box. Replace it and straight away hold the OFF button down on the remote. Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
Cheers Bodsy if you're ever down north Kent give us a shout, I would like to have my car Bodsyed
Lol. Will be in Chelmsford towards end of next week, but not sure thither is much I can do with your HSE. |
Thanks it's a Autobiography on 12 plate. |
