Home > Technical > Brakes stuck on!
Panavia man
Brakes stuck on!
Hi, only had my 2008 TDV8 a week. Drove it yesterday and all was well, got in it this morning put it in D and got a very strange noise from the rear. Looks like the brakes are stuck on. The red parking brake light is on and a yellow brake warning light has come on. Can anyone help please. Thanks
Chris
Post #478739 Wed Nov 04 2015 9:40am
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
EPB jammed the rear shoes. Big Cry you will need to strip the rear drums to find out the problem, common on the sports and Discoverys.
Post #478747 Wed Nov 04 2015 10:14am
muddywheels
Milk Float Man
If you bought from dealer should be covered under warranty Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #478748 Wed Nov 04 2015 10:16am
Panavia man
Ok thanks both for the replies. I got a warranty wise policy with it, lets hope its covered!
Post #478759 Wed Nov 04 2015 11:07am
muddywheels
Milk Float Man
Don't be fobbed off - it's dealers responsibility regardless of what warrantywise say Confused
https://www.citizensadvice.org.uk/consumer...-used-car/ Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #478760 Wed Nov 04 2015 11:11am
Panavia man
Just spoken to the dealer who suggested I try warranty wise first!
Post #478762 Wed Nov 04 2015 11:28am
muddywheels
Milk Float Man
They would as they are hoping not to spend anything Confused Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #478766 Wed Nov 04 2015 12:35pm
Panavia man
I've pushed back - it's off to a LR specialist garage now. Sure they will diagnose it quickly. It does make a horrible noise when you try to release it the parking brake!
Post #478775 Wed Nov 04 2015 1:37pm
Lost for Words
They don't need to; it already has been... Wink Visiting from DISCO3.CO.UK
Post #478776 Wed Nov 04 2015 1:46pm
Panavia man
Yes - sounds like it! I'm new to this game, I believe it's best to leave the handbrake off on these? Looks like the last owner hasn't been using it and it's locked now I have started using it.
Post #478779 Wed Nov 04 2015 1:55pm
Disco_Mikey
If you use it, the shoes wear, go out of adjusted, and squeak
If you don't use it, they seize up and lock on, as you have found
The key to a healthy, happy EPB, is maintenance Thumbs Up
Post #478780 Wed Nov 04 2015 2:00pm
muddywheels
Milk Float Man
I only used mine on hills when parked - my DS comes on automatically when I stop engine which is a pain Confused Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #478782 Wed Nov 04 2015 2:06pm
Lost for Words
As Mikey says, using it needs maintainence, not using it needs maintainence - you may as well take advantage of it (and you don't want to put strain on the parking pawl). Thumbs Up Visiting from DISCO3.CO.UK
Post #478784 Wed Nov 04 2015 2:07pm
Panavia man
Thanks for the replies. I'm a bit dissapointed as the car is a one owner with a full service history. Surely EPB should have been maintained regardless of use?
Post #478786 Wed Nov 04 2015 2:10pm
Lost for Words
I wouldn't be too disappointed - it often doesn't get the attention it needs, and if you don't have a trustworthy mechanic, it can be hard to know if the EPB has been done properly unless you've done it yourself. It may well be time for a new set of shoes - mine were in a right state when I first went to change the brake discs. Thumbs Up Visiting from DISCO3.CO.UK
Post #478790 Wed Nov 04 2015 2:21pm
