Home > Technical > activation with IIDTOOL BT VERSION for fbh.
Page 1 of 3 123>
Ned
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Fuji White
Hi guys can someone please talk me through the activation process on my IIDTOOL BT VERSION to activate the fbh please I am going to order the receiver antenna and remote tomorrow , or if someone is down near Welling Kent , my phone number is 07757674471 many thanks Ned.
Post #478669 Tue Nov 03 2015 6:48pm
fkarim
http://www.rrsport.co.uk/forum/topic34755.html
Also search this forum and disco3.co.uk for any specific questions. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory
Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond
Post #478672 Tue Nov 03 2015 6:59pm
Ned
Thanks I have had a look, I have a my12 autobiography just looking for someone to talk me through the activation process once I have connected my IID TOOL to the car.
Post #478676 Tue Nov 03 2015 7:34pm
fkarim
There are 3 settings that need to be configured. They are discussed on the thread above and others on the Sport and Discovery forums. From memory they are FBH Call Start, Fuel Burning Heater and Timed Climate. I have sold my MY13 which wasn't much different from MY12 otherwise I would have plugged my IIDTool in and given you the exact values for these settings. I will try anyway: FBH Call Start = Fitted Radio, Fuel Burning Heater = Fitted, Timed Climate = Enabled. Basically you plug the tool in, connect your phone via BT, go to the Car Config menu, select the HVAC ECU/menu and select the appropriate values for these settings and follow the instructions from there. It is very straight forward.
Just make sure your car battery has a very healthy charge level or you connect it to a power source such as a trickle/maintenance charger before starting. It is normal to get faults while updating the CCF. If the update fails just try again. That's my experience with this stuff and I think pretty much covers it all. Perhaps a current owner with an IIDTool can walk you through the process as you do it if you still feel you need it. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Post #478688 Tue Nov 03 2015 9:08pm
Ned
Flaring, big thank you for your knowledge and time thanks very much.👍
Post #478702 Tue Nov 03 2015 9:58pm
myfirstrrs
Hi Ned,
I managed to do this using information from this forum, it was surprisingly easy. The IID Tool is really quite intuitive but it is useful to know the terminology that fkarim gave you.
Good luck and please let us know if you have any problems.
Post #478703 Tue Nov 03 2015 10:06pm
Ned
Thanks myfirstrrs
I have just ordered the remote off fee bay will order the rest tomorrow and will most certainly let you good guys know how I get on thanks so much for help 👍.
Post #478710 Tue Nov 03 2015 10:36pm
Disco_Mikey
https://www.gap-diagnostic.com/faq/
Scroll down to "How do I enable timed climate"
Post #478712 Tue Nov 03 2015 10:53pm
Ned
Thanks soooo much disco mickey really helpful top guy .
Post #478713 Tue Nov 03 2015 10:57pm
Disco_Mikey
Post #478714 Tue Nov 03 2015 10:59pm
TPS
If I just wanted to enable the timed climate option do I still need to set all three settings as below?
"For 2010 and up vehicles fitted with a FBH (not the electric heater)
IIDTool Menu->Car Config->HVAC Ventilation->
•FBH Call Start is equal to Fitted radio. This is the one related to the remote.
•Fuel Burning Heater is equal to Fitted parking heat
•Timed Climate is equal to Enable"
or just ensure the FBH is set to fitted and the timed climate is equal to enable
So far I enabled the Timed Climate option and no menu item has appeared on the touch screen -----------------------------------------------
RRS SDV6 HSE MY2012 Orkney grey, Oxford leather Ivory seats Ebony carpet, Anigre wood trim, enhanced design pack.
Post #487294 Fri Feb 12 2016 6:33pm
Lonerangerv8
United Kingdom 2007 Range Rover Sport TDV8 HSE Santorini Black
Just thought I would ask as a newbie to RRS.
Do all tdv8 sports come with the fbh fitted or was it an option.
Cheers.
Post #487305 Fri Feb 12 2016 9:01pm
Bodsy
Site Sponsor
They all come with it (uk spec diesels anyway) but we can't tell from your profile what car you have. On the rrs2, it is an option. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #487331 Sat Feb 13 2016 9:30am
Lonerangerv8
Hi Bodsy,
I don't pick mine up until the 5th March.
It's a 08MY on a 57 plate tdv8 so I presume it has it fitted.
When I went to view it, it was lashing down with rain so I only managed a quick look under the bonnet and I can't remember exactly what was under there. Sad
Can't wait until I get it as its been such a long time searching for the right one.
Only done 48k and one retired gentleman owner who has cherished it.
Cheers, Phil.
Post #487344 Sat Feb 13 2016 11:20am
Bodsy
Site Sponsor
Yes it will have the FBH fitted, but you can't enable timed climate on that year. You cAn fit a BAS FBHIC to it though. I can supply and fit if interested. Thumbs Up
Sounds like it's had an easy life so far which is always good news! Thumbs Up Bodsys Brake Bible
See it HERE
Post #487350 Sat Feb 13 2016 11:57am
Page 1 of 3 123>
