Home > Maintenance & Modifications > Sump removal/Cleaning on 2009 RRS
Roy
Good morning guys, refitting recon turbos to a 2009 Range rover sport.
Been advised to change relevant hoses which is no problem however i have also been advised the sump will need cleaning out.
Does the engine have to be dropped to remove the sump?..could do with knowing the best/quickest way to get it off, many thanks in advance, Roy
Post #477950 Tue Oct 27 2015 10:58am
What engine? The TDV8 is an engine out job to do the sump I believe. 2012 SDV6 - it's missing a couple of cylinders
Post #477951 Tue Oct 27 2015 11:04am
Roy
Hi mate thanks for the reply, its a TDV6 HSE , cheers
Post #477952 Tue Oct 27 2015 11:09am
Lost for Words
Have you considered the difficulties in calibrating such turbos correctly when deciding on the recon route? Whistle
(Also, is that 2.7 or 3.0? You say "turbos" so may we assume the latter?)
Edit: ...and welcome to the forum, of course. Smile
Thumbs Up Visiting from DISCO3.CO.UK
Post #477960 Tue Oct 27 2015 2:21pm
