![]() | Home > General > RANGE ROVER SPORT DOOR LOCKS |
| Patrick16 Member Since: 01 Feb 2013 Location: West midlands Posts: 3
hi everyone has any one had a problem like this i have a 2007 range rover sport 3.6 diesel
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
Do a search on here and the Disco Forum, door locks failing is a common issue. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
| Mark41 Member Since: 30 Apr 2015 Location: Preston Posts: 18
driver's door lock failed a couple of months ago on our 2006 TDV8. Had it replaced under the warranty be bought with the car. Now seems there is problem with the passenger door lock as it won't lock untilthe remote is pressed 2 or 3 times |
its all four doors on mine and switch inside ??? |
| mr_spaceuk Member Since: 26 Apr 2015 Location: Berkshire Posts: 40
I had to replace the drivers door lock, rear near side lock and both boot catches and both boot buttons.
Hi yes tried all locks with spare one it works few days then stops working then just starts working again someone has said there is a sensor in the roof lining that senses if the car is occupied ??? |
| All times are GMT |
