| RRSPORT.CO.UK | ||
|  | Home > Technical > Hdc fault since changing lower wishbones |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477    | Welcome.  | ||
|  Sun Oct 25 2015 10:37am |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477    | Oh, and best to fill in your vehicle profile (if you think you have, check you've selected the colour).  | ||
|  Sun Oct 25 2015 10:38am |
| cookie7280 Member Since: 20 Oct 2015 Location: romsey Posts: 5    | I did the wish bones so no alignment yet
|  Sun Oct 25 2015 10:39am |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477    | It needs a diagnostic tool to calibrate it, but you also need to get the alignment done ASAP.  | ||
|  Sun Oct 25 2015 10:43am |
| cookie7280 Member Since: 20 Oct 2015 Location: romsey Posts: 5    | is there anyway to physically check the abs sensors or does it need plugging in for this ? | ||
|  Mon Oct 26 2015 12:06pm |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477    | Needs to be plugged in to read the data from them, but you could check for physical damage to the wiring etc. I think it highly likely that the issue is the SAS and/or alignment though.  | ||
|  Mon Oct 26 2015 12:14pm |
| cookie7280 Member Since: 20 Oct 2015 Location: romsey Posts: 5    | okay thank you I am going to get it plugged in tomorrow and hopefully sorted | ||
|  Mon Oct 26 2015 12:20pm |
| garyd18166 Member Since: 29 May 2015 Location: leeds Posts: 24      | Hi , i had the same problem, start the car up and do full left lock , and then full right lock, also check brake pad wear sensors...
|  Sat Nov 14 2015 8:56pm |
| garyd18166 Member Since: 29 May 2015 Location: leeds Posts: 24      | I have the same problem
|  Sat Nov 14 2015 9:01pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | The steering angle sensor needs calibrated using a diagnostic machine, not by working the steering lock to lock   | ||
|  Sat Nov 14 2015 9:24pm |
| B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420      | Had the same problem, changed the brake light switch under the dash and all was well again   | ||
|  Wed Nov 18 2015 6:55pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | A blown brake light bulb can throw an HDC error too. 2012 SDV6 - it's missing a couple of cylinders
|  Wed Nov 18 2015 7:43pm |
| garyd18166 Member Since: 29 May 2015 Location: leeds Posts: 24      | I have the new updated LED'S on the rear, | ||
|  Wed Nov 18 2015 8:58pm |
| Posting Rules
