Home > In Car Electronics > RRS 2008 iOS 9 issues
Ian.H
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
Hi all..
Has anyone running a pre-2010 RRS updates their iPhone to iOS 9 and still had the handsfree bluetooth work still?
I get all the displays showing the expected results, but I get no sound through the system any more. Even if I try to make a call from the car using the phonebook / last numbers menu, it seems to silence the music as expected then kind of disconnect from the system just leaving 'Bluetooth' displayed on the head unit display and the music then continues to play at the original volume.
Incoming calls are much the same.
I haven't yet had a chance to revert back to a pre-iOS 9 backup bit wondered if it was just me.
Cheers..
Ian
Post #477098 Tue Oct 20 2015 2:53am
Bodsy
Site Sponsor
Mine works fine. D3 is same as rrs. Thumbs Up
Have you tied removing the battery cables, holding them together for 20 seconds and then re attach to battery.
Are you on the latest Blutooth version in the car? I.e. Do you get the phonebook contacts on th radio screen? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #477115 Tue Oct 20 2015 8:32am
Frax
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
If you never had the phone book download or display you need to get your Bluetooth module replaced with an updated one.
Do a search on here for one as a boy does an exchange service, I got one when I had my 2007, quite easy to fit. Lot of Landcruisers now sold
Audi TT 240 Sport now sold for.
RRS 2.7 HSE Now sold for.
RRS Autoibiography 2012
Defender 300tdi 90
Post #477154 Tue Oct 20 2015 4:03pm
Bodsy
Site Sponsor
Don't need to search very far, as that'll be me then. Lol. Thumbs Up
Let me know if you need an updated module Ian. Thumbs Up Bodsys Brake Bible
See it HERE
Post #477156 Tue Oct 20 2015 4:12pm
Ian.H
Many thanks for the replies and suggestions.
I do have my phonebook imported (including last numbers (dialled, missed, received) so I'm guessing that I have the latest BT module installed.
I disconnected the battery and connected the cables as suggested, but this doesn't appear to have done the trick.
If I hit the phone button on the dash and then pick a name from either the address book or a recent number and select it, the call will be made, but I don't hear anything through the car. I can't adjust the volume to test that as it never gets to the point where the BT connection actually accepts the phonecall connection (ie: as soon as someone picks up, the BT connection seems to be dropped, reverts back to just reading 'Bluetooth' in the head unit display and if I'm trying to adjust the volume, it just changes the music volume instead.
I'm going to try and connect my better half's phone later (same phone, but I think she's still on 8.0) just to eliminate that for myself.
Is there anything specific to the BT stuff connected to the HK amp under the driver's seat? Something I can potentially unplug and plug back in?
Cheers..
Ian
Post #477187 Tue Oct 20 2015 7:24pm
scrumps
Both SWMBO and myself had issues with our 5S & 6 pairing with both my RRS and her D4 after iOS 9.0.2 upgrade.
Worked a treat after a full re-boot of both phones.
Migh be worth a punt.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #477215 Tue Oct 20 2015 10:01pm
Ian.H
Thanks Scrumps.
I checked with Clare's iOS 8.0 iPhone 6 and this is behaving in the same way as mine.. so looks like there must be something with my motor afterall Sad
Seems odd that it's only the audio that's broken (head unit works fine for everything else.. CD, radio, etc).. so the connection from head unit to speakers is fine.
Cheers..
Ian
Post #477217 Tue Oct 20 2015 10:29pm
