Home > Technical > steering wheel vibrating
halisemre
I have bought the car 1 week ago it is now 400 km, when I am driving at the speed of around 100< the steering wheel is shaking little bit what could it be...
could this be an allingment issue in this short time period.
Post #4306 Mon Oct 31 2005 2:29am
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
Possibly, don't discount the simple remedies that you'd normally think about on an older car. I had to have a full 4 wheel alignment done on mine after 1 Week! L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #4317 Mon Oct 31 2005 8:30am
Esoteric
Usually a vibrations is caused by a wheel out of balance. Sometimes they are not balanced correctly from the start and other times some of the weights can fall off throwing it out of balance.
Post #4756 Fri Nov 04 2005 3:18am
Tim in Scotland
Have you taken it through any sticky mud? If so put the steering on full lock one way and then look in the backs of the wheels for lumps of mud stuck inside the rims these act like unbalancing weights. Turn the wheels to full opposite lock and do the same thing again. This was what caused mine to be wobbling.................. but then I had been offroading in sticky mud. Laughing 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #4770 Fri Nov 04 2005 10:18am
Quasimoto
United States
I sometimes notice vibration, but it appears temporary. I attribute it to cold tires, though there are many theories...
http://www.rangerovers.net/forum/viewtopic.php?t=2942 -QM
Post #4999 Wed Nov 09 2005 3:45am
LeePeto
Get the wheels checked, hopefully will fix it.
Post #5342 Thu Nov 17 2005 12:49pm
RRUK
On my last car cold tyres would cause slight vibrations for a mile or so. L319 D4 HSE
1982 Series 3 SWB
Post #5354 Thu Nov 17 2005 3:40pm
Persuader
Sounds to be definitely the wheel balancing. I'm sure that it's just that a wheel balance weight has come off. Get all fours wheels balanced and that should fix it. 2013 New Range Rover Sport HSE SDV6
2008 Audi Q7 4.2 TDI
2006 Toyota Vigo Truck 3.0D4D.
Post #5456 Sat Nov 19 2005 11:20am
BIG BAD RANGE
I HAVE JUST HAD DELIVERED A RANGE SUPERCHARGE AND NOTICED A WHEEL VIBRATION ABOUT 70MPH HAD ALL THE WHEELS RE BALANCED STILL THERE !!! THEN TOOK THE CAR TO ELITE IN ESSEX TO CARRY OUT A 4 WHEEL ALINEMENT CAR IS PERFECT NOW WELL WORTH CHECKING.
Post #5828 Thu Nov 24 2005 11:33pm
