![]() | Home > Technical > Help needed to identify missing Front End part 3.6 TDV8 |
The TDV8 (and the supercharged) has an auxiliary radiator on the OS in that position so perhaps the hoses connect to that?
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4516 ![]() ![]() ![]() |
The ARC system runs at upto 50bar. If your going to repair it, hose won't take the pressure |
Pelicansteve Member Since: 13 Oct 2015 Location: Middlesex Posts: 5 ![]() ![]() ![]() |
Thanks for the info Paddi will have a look at the auxilliary radiator and i did try to subscribe to topix last week, but i've been unable to login since i registered. Just keep getting the error message to contact customer services.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9112 ![]() ![]() ![]() |
Yes, those two pipes should connect to the auxiliary radiator. The TDV8's auxiliary rad is just part of the standard cooling system - it's an extension of the cooling system in parallel and controlled by a thermostat. The Supercharger auxilliary rad is connected to the oil cooler I believe. 2012 SDV6 - it's missing a couple of cylinders
Thanks. |
Just seen your pictures. Those hoses, as stated, go to an auxiliary radiator
Thanks a lot for your reply Disco Mikey.
