![]() | Home > General > SE v HSE |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145
Thanks very much Tim.
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
Just to be clear, don't expect the compressor to stop as soon as the car is raised - the initial pressure is sourced from the gallery, which then takes a little longer to re-fill. |
IIRC the engine icon light should come on briefly as part of the start up checks, like an airbag self check does. If no icon on the self check then suspect that it has been hidden with insulation tape................ and is permanently on, which could be because of EGR or Turbo issues........... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Oh and what does the gong mean at the end of the ignition sequence? Ready to start? |
Could be any of a number of warnings! From seat belt not done up through a door not fully closed, tail gate not latched to washer bottle low to impending doom in the engine! You can recall the most recent warnings through the column stack IIRC (it is a 5 years since I last drove an RRS1!) 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Basically, it's a systems check type thing. You can get various erroneous bongs can on the earlier vehicles (2005 mainly) which got cleared up with later instrument pack software versions. |
Where are the VIN numbers located on these? |
Bottom left of the windscreen, under the wiper blade. |
Anywhere else? |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156
Front Slam Panel under Bonnet and Stamped on Chassis under Front of Drivers Door.
If you should be particularly concerned about it, it's also stored in various ECUs. |
That's guys.
| All times are GMT |
