Home > General (L494) > L494 dislikes? What drives you bonkers on your new 494....
Page 3 of 3 <123
Triumph_Dave
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Autobiography wrote:
The leather quality is noticeably better on Autobiography derivatives vs HSE derivatives IMHO.
Having looked at HSE and AB models compared to my previous HSE Black addition, the newer model leather work is not as well put together overall as the older 2103 model. D4 2012 Santorini Black gone
RRS 2013 Santorini HSE Black gone
MY2016 RRS HSE Dynamic arrived September, but will it stay.. maybe not.
Post #475746 Thu Oct 08 2015 2:21pm
Triumph_Dave
iainm wrote:
[quote
5. Turbo lag on pull away, worse than previous model. Will see if this improves as engine loosens.
Had this on mine - drove me nuts - its a quick fix that Strastone knew about; brake and accelerator cannot be used at the same time; what was happening is the brake was not releasing once accelerator was pressed; only a split second or two, but enough to make the car do sod all for a couple of secs when trying to pull away at roundabouts etc. They adjusted something on the brake and hey presto- no turbo lag anymore.....
Just have to sort the oil leaks now.... Big Cry[/quote]
Thanks for that , looks like the car will have to go back to dealer to check loose rear quarter panels, so i will mention the lag and your experience. D4 2012 Santorini Black gone
Post #475747 Thu Oct 08 2015 2:26pm
GJW1
Did you get your lag problem sorted Triumph_Dave ?
Post #477354 Thu Oct 22 2015 12:31am
Triumph_Dave
Not yet given to the dealer due to work/travel commitments, but over the last few days it has got better.. I was told on my last model that the system initially "learns" the drivers response, so maybe that has helped, if so its taken 500 miles to do it. Interestingly the "clunk" from the autobox when drive is engaged on 1st morning start up has also stopped??. Would not think its connected though..
Dave D4 2012 Santorini Black gone
Post #477400 Thu Oct 22 2015 3:46pm
Adam RRS
haha Farmer youve got this spot on!!!
That smear on windscreen i thought was just my car?! I am on my 4th wiper!
Also, i miss the tray that used to lie ontop of the arm rest storage, now i just have a deep hole that i have to dig everything out of when searching WINNER - 2009 Best in Class Range Rover Sport Award
MY14 Corris Grey RRS HSE SDV6
Post #478172 Thu Oct 29 2015 12:21pm
rangiejools
Australia
Adam, try some Rainex on your windscreen. Helped lessen my smudge a little. RRS P460e
1983 2 door Range Rover ARB Bar X9000 winch ARB Rear Bar now semi retired.
Many big trips done in this one.
1982 Rangerover nearly restored.
22 Defender D250 with lots of stuff for outback touring
Nice 2013 Freelander TD4 manual (for daughter to learn on) with much better stereo compared with previous SD4 SE with Meridian which sounded bad!
2013 Land Rover Defender ute.
Post #478174 Thu Oct 29 2015 1:03pm
Adam RRS
Righto! WINNER - 2009 Best in Class Range Rover Sport Award
Post #478658 Tue Nov 03 2015 5:04pm
having the Bluetooth on means that the music is interrupted all the time when the phone receives a message.
And also when the RDS changes frequency, the system beeps.
Not the mention that I have yet to find a USB stick that gets recognised by the Meridian system Evil or Very Mad --
Post #558447 Fri Jun 08 2018 8:08am
IRBails
Australia
Thinking about this the things that annoy me are few but ?
1) Great sound system with very low tech interface, can't have Bluetooth and USB source connected at same time. Also input
selection via steering wheel is standard on most vehicles but not the RRS.
2) Very slow Nav
3) Voice control useless as tits on a Bull
4) No Android or Apple connect in MY2016
5) Noisy HUB fan
6) No Tyre pressure monitoring system standard on my year. Should be there for the entry price.
7) No access to air , this should be standard so I can fix punctures with a plug and don't have to remove wheel, a great feature
on my previous car.
Cool Stop Start feature as mentioned by others should be selectable,
9) Vibrating front discs cured by me by changing pad brand and material , Dealer just kept putting OME back on and trouble
returned after a few months.
10) Auto Wipers will go to flat out at times requiring switch off and restart.
11) Heated seats not standard, should be in this price range. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #558650 Mon Jun 11 2018 12:22am
Chips
For Me on an MY16 A/B
The responsiveness of the Sat Nav /ICE goes without saying , you have to learn to press once and wait , not really in my nature !
The shift from forward to reverse doesn't always keep up either , meaning you end up screaming the balls of the engine in neutral rather than zooming off in reverse/ Drive when in a rush .
The angle of the Sat Nav screen in the dash is not the best meaning the clarity of the image is not as sharp as it should be , despite being 6ft you still have to sit up/forward to get a clear image .
The climate seats , in cool mode it cools the base but hardly the back rest at all , I would far rather it was the other way around to keep the back of your shirt dry in hot conditions , if you switch off the base and leave the back on only I don't think it does any cooling at all ! Secondly the three heat settings don't seem to do anything , it's just flat out on all three meaning you are for ever switching it on and off in the winter , the basic electric seat heaters in my Disco 3 are far better !
All of that aside , the rest of the car , especially the ride and handling more than make up for it and I would never want to go back to a steel sprung Q7 despite the in car electronics being about a 100 years ahead in the Audi !
Post #558673 Mon Jun 11 2018 10:42am
Tim in Scotland
Sounds like the standard non cooling seats are the better option then - mine heat up very quickly and I have to switch them off before they do it automatically because they just get uncomfortably hot. I’ve never found that my bum or lower back gets too sweaty perched on the standard seats. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #558683 Mon Jun 11 2018 12:41pm
Page 3 of 3 <123
