![]() | Home > Wheels & Tyres > tyre sizes |
I use 275 45 20 and no issues here |
+1 no problems. 2008 G4 RRSport TDV8 current
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5068 ![]() ![]() ![]() |
+2 Have run that size on two Sports over last five years absolutely no issues. No significant variation in speedo reading either.
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
+3 I have 275/45/20's, the speedo is within 1 km/h compared to GPS indications. Much better ride and better presence. Regards etc.,
wings21660 Member Since: 11 Feb 2015 Location: Gretna Posts: 65 ![]() ![]() ![]() |
I work for Pirelli tyres in carlisle there's no issues with changing the sidewall size at all |
Just to point out, they do all have to be the same size. (Merely stating this as a precaution ) |
Rolo Member Since: 29 Feb 2016 Location: Manchester South Posts: 47 ![]() ![]() ![]() |
Tried to buy Michelin CrossClimates in 275/45/20 to replace my 275/40/20 because the CrossClimates are not available in 40. Michelin wouldn’t approve it under any circumstances, so tyre fitter wouldn’t sell them to me. Even Camskil would not approve. |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1195 ![]() ![]() ![]() |
If you want a slightly more comfortable ride, you can also go for 255/55R20 |
They are your wheels, its up to you what you do with them ![]() 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18” Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning 😎 |
As MICHELIN only recommends using the original tyre size that was given by the car manufacturers, therefore we cannot ask for approval from Land Rover.
3 tyre suppliers wouldn’t sell 45s to me. One said that if I turned up with tyres without wheels in order to fit as a separate transaction, the mechanics would spot the difference and check and then not install.
The MICHELIN Latitude Sport 3 is a summer tyre model, as you also mentioned, and summer tyres were designed to be used when the daily temperature is above 7 degrees, we do not recommend to use it on
No Tyre manufacturer is going to approve a size not specified by the vehicle manufacturer, the same as no Dealer will say it is o.k to fit a size not specified by the Vehicle manufacture. My guess for this would be mainly a Liability one in the event of a accident or some issue as a result using unspecified parts, tyres or anything else, as the first thing someone is going to say is but Land Rover, Michelin or who ever told me it was o.k. to use that size. That aside I have used Michelin, Continental, Pirelli and Verdestien all in 275/45 x 20" over the last five years on Sports and have never had a problem or issue with a Tyre or Distributor selling and fitting a tyre size I asked for and that includes Camskill twice. There are enough Members on the forum that have now changed to that size tyre that had there been any problems it would have been highlighted by now.
Probably my fault for asking for advice and not telling them what I wanted.
