![]() | Home > Maintenance & Modifications > Brembo six piston calipers |
PN for discs is LR016176. Pretty sure bolts are the same. Wear sensor is different - LR019401. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4890 ![]() ![]() ![]() |
Discs are 380mm Dia. I think the Calliper Mtg. bolts are the same but the wear sensor is different.
Hi
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4354 ![]() ![]() ![]() |
Caliper bolts are the same
RR-CBY Member Since: 28 Jan 2015 Location: Derbyshire Posts: 13 ![]() ![]() |
Thanks for the reply's guys I'll get some discs and a wear sensor ordered then |
Disco Mikey, do you know what size disc is already on the MY2010 TDV8? As the existing back plate is approx 20mm bigger than the existing disc so was hoping I could still use them? If not have you got a part number for the back plates I would need?
4 pot Brembos are 360mm
Looking at the Parts List for the 2010 on RRS they appear to be the same LR013665 and LR013666 however suggest you check with dealer just to confirm.
Cheers for that Col |
As a back up I've also found these on eBay
I have Delhi discs on mine, and they cost me a whole lot more than that. Make sure that is the price for a pair, or individually... |
tonywolf Member Since: 14 Sep 2015 Location: Devon Posts: 97 ![]() ![]() ![]() |
Just got these bad boys, there massive :thumbs: :thumbs: Just got to find the other bits and pieces now!!
http://www.ebay.co.uk/itm/RANGE-ROVER-RANG...SwgQ9ViAVv
Good price for those discs |
