![]() | Home > General > Q393 - Detachable Tow Ball and Supplement - LR Sevice Actio |
I would not be happy having to check my tow bar every couple of hours. |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
It's not right |
| monty19 Member Since: 12 Mar 2014 Location: boro Posts: 326
ours was in yesterday and they said all is ok, hope so because im pulling a twin axle caravan |
| savi18 Member Since: 02 Aug 2015 Location: Gore. South Island NZ Posts: 154
You got me worried now just received my swan neck hitch to tow double axle caravan weighing in approx. 2000kgs, have not towed with it yet as it sits to low to the ground to connect caravan(see my post) going to have to think on this one don't want to lose a new caravan. |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
The detatchable towbar is fine as long as it's removed when not used (NB: They can also be stolen in 5 mins so this is advisable anyway.) and kept clean and greased. If you're towing often, or large noseweights, you need the fixed bar. |
The detachable swan neck hitch is sitting to low to attached caravan so as you mention will have to go for fixed tow bar hitch, luckily over here in the South Island NZ never heard of one be stolen, but the swan neck hitch I bought from England, well you never know, Cheers Derek(ex Lancashire Lad) |
| Mail Order Ride Member Since: 28 Feb 2009 Location: UK Posts: 131 |
OK got my letter today and having read this thread and the one on D3 Im not sure how to proceed
I'm asking? If the towbar is functioning well, and it and the receiver are not worn, then you won't need any change. At least one member on DISCO3 has been provided with a new swan neck instead (with a new crossmember). If that's what I wanted, I would be telling LR that I need the departure angle for off-roading.
The action was suspended for a long while, which IIRC is believed to be due to an unexpectedly high number of crossmembers being in need of replacement. FWIW, I have still yet to receive a letter...but I have a fixed bar, which fits snugly, so it doesn't effect me. Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver
| RRS Daz Member Since: 22 Jan 2012 Location: Yorkshire Posts: 797 |
My sport had a dealer service done this week and was checked for the recall but hadn't had a letter about it. |
| Shiny Silver Member Since: 16 Feb 2012 Location: Cambs Posts: 70
I had my detachable tow bar checked last year by the LR dealer and was told it was within tolerances. I have noticed after unhitching the detachable has some side to side movement, but twisting the green knob then removes the slack. After towing and unhitching last weekend the side to side movement was about an inch movement!!!!
| All times are GMT |
