![]() | Home > Faults & Fixes > Inner tie rod |
| Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203
Well fitted new inner tie rods today just to see if it solved movement issue, NO as suspected it must be the rack internal shaft/collar/pinion or something in there, anyways I've ordered a refurb steering rack with 2 year warranty, hopefully will sort it once and for all.
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
Replied on DISCO3. |
Cool, thanks a lot for reply, also that's noted for future. Thanks again. |
| alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83
I'm going to do my tie rods soon - did you need special tool to remove the inner ? Btw , I got cold climate fluid from the gm dealer - similar texaco spec to LR - ac Delco 10-5044 made in Belgium |
Hi, no need for special tool, it was surprisingly easy, Just used a large adjustable wrench to undo/do up inner tie rod nut, also count the amount of turns on outer tie Rod when removing to get close when fitting onto new, but will def need wheel alignment once fitted, you probably want brand new but I've got a as new pair inner tie rod if you want for a small fee, only fitted then removed due to fault being steering rack not tie rods. There not expensive anyway but thought I'd ask. 😊 |
| All times are GMT |
