Home > General (L494) > InControl Remote Apple Watch Support |
Bobajobbob Member Since: 01 Jun 2015 Location: Kent Posts: 137 |
It's a bit pants really. Nice idea but poorly executed. 4 buttons that don't fit onto the screen without scrolling slightly and corrupted text that just sits top left. Maybe the developer will actually buy an watch and test it next time.
Mon Sep 14 2015 10:01pm |
Mon Sep 14 2015 10:04pm |
JasSmiths Member Since: 29 Dec 2014 Location: Staffordshire Posts: 53 |
Ah! Sounds like a good well built app then don't get my car till November so I've not been able test it! |
Mon Sep 14 2015 10:05pm |
With a bit of luck they will have improved it by then. I could sort it out in about 20 minutes and a real developer in about 5.
Mon Sep 14 2015 10:31pm |
R444SPT Member Since: 20 Mar 2015 Location: Offroad somewhere Posts: 217 |
I'm all for constructive feedback, but really the state of that can't of been developed by anyone that would consider themselves an IT professional / software developer. My 6 yr old nephew wouldn't do any worse.
Tue Sep 15 2015 7:49am |
Hedders007 Member Since: 19 Mar 2015 Location: Sussex Posts: 86 |
....And there seems to be no way of turning on the Park Heating either. If it's available on the iPhone, then why not the watch?
Tue Sep 15 2015 8:09am |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1667 |
It's a pity also it can't appear as a Glance. |
Tue Sep 15 2015 8:15am |
jimmy-taylor Member Since: 15 Sep 2015 Location: Bristol Posts: 3 |
Not sure I agree with you, if you had all that info crammed onto that tiny screen the text would be too small to read, especially on the 38mm. They clearly have tested it or it wouldn't work |
Tue Sep 15 2015 2:11pm |
If they have tested it and think this is acceptable then they are not qualified to develop in this medium. I disagree with you on the size of buttons/text. There is plenty of room even on the 38. If the iconography was any good you wouldn't need text.
Tue Sep 15 2015 2:54pm |
I doubt they designed it on opinions of whether its big enough or not, Apple will set guidelines that state minimum text sizes to make sure its legible at various sizes and in different lighting conditions, which I imagine they have to adhere too.
Tue Sep 15 2015 3:07pm |
Icons would work fine without the text. The app is functional but poorly designed. Hopefully it will improve. |
Tue Sep 15 2015 3:37pm |
I disagree, icons need a label for context, plus you get more info without having to go into a section.
Tue Sep 15 2015 3:42pm |
A good icon doesn't need text. If you look at the app screen of an Apple Watch you won't see any text. The good icons don't need it.
Tue Sep 15 2015 4:28pm |
This in my opinion is its biggest downfall, even if the glance just allowed you to Lock/Unlock along with the current status. |
Tue Sep 15 2015 4:54pm |
