Home > In Car Electronics > Retrofit bluetooth
Roy1980
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Retrofit bluetooth
Hi guys,
I'm new to the site and also to the world of Range Rover,
I've recently bought my car and attempted to connect my phone and several others but couldn't get a Bluetooth connection, pulled the boot trim and there's no module just the radio module, I have the microphone wired in above the interior light and voice control. I have read about land rover part no VUB501152 and thought about getting this installed as I want to keep the car as standard as possible,
Went into dealership today and got quoted Ł269 for the kit but they said this kit probably won't fit as the car has to come pre wired from the factory even though there is wiring with the kit,
I'm looking for some advice on if this kit will actually fit/work and if anyone has done this any tips,
Sorry if this has been answered before I had a quick look through the previous posts but didn't see anything.
Cheers,
Roy
Post #459163 Tue Apr 14 2015 5:01pm
flack
You need to fit the BT module from a D4, it more or less a plug and play kit, you would then need it enabling. Contact Disco_Mikey I am sure he can sort you out.
Flack Thumbs Up
Post #459184 Tue Apr 14 2015 8:31pm
Roy1980
That's great, thank you
Post #459188 Tue Apr 14 2015 8:44pm
gary3306
England 2013 Range Rover Sport SDV6 Autobiography Fuji White
Did you have any luck with getting this done mate. I'm in the same boat and if this kit does the job, then happy days. I sent Disco-Mikey a PM but he hasn't read it yet.
Post #473099 Mon Sep 14 2015 12:43am
Bodsy
Site Sponsor
I wouldn't use that kit tbh, input will work, but you are better off having the d4 module retrofitted. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #473108 Mon Sep 14 2015 9:04am
gary3306
So Bodsy, how much am I looking at for you to do that to my car? I was also looking at the mObridge system. That is good but quite pricey.
Post #473116 Mon Sep 14 2015 10:39am
Bodsy
Site Sponsor
The Mobridge kit is really quite pricey, you're right.
I'll send you some info. Thumbs Up Bodsys Brake Bible
See it HERE
Post #473117 Mon Sep 14 2015 10:41am
gary3306
Post #473119 Mon Sep 14 2015 10:47am
TheWojtek
Bodsy - would you be so kind to include me in your PM regarding BT info? I'm in exactly the same boat as Gary (buttons on the steering wheel, no BT module, no harness visible in the rear right boot area, no I don't want to fork out 300 quid for a M0bridge BT, yes, I've seen Ford Focus BT modules that cost a fraction of LR items and look suspiciously similar). Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #473121 Mon Sep 14 2015 10:52am
Bodsy
Site Sponsor
See it HERE
Post #473123 Mon Sep 14 2015 10:58am
