Home > General > Front Propshaft |
rayc59 Member Since: 12 Sep 2015 Location: Scotland Posts: 19 |
Ok lads looking for some help here as i have googled this to death and also asked on other forums but getting nowhere my front prop shaft going into the diff is really badly grinding and no reverse drive, is this a easy fix with new prop. the vehicle is a 2006 sport auto with 74k on the clock i have already done new air compressor two front wheel bearings new disks all round, new rear brake caliper 4 new tyres and its starting to get me down it does not lead a hard life as i work offshore so i only drive it two weeks a month
Sat Sep 12 2015 6:51pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4349 |
Ray, I have never had a failure like that in 10 years
Sat Sep 12 2015 6:57pm |
thought it was the driver side drive shaft but when i jacked it up and turned the wheel by hand the noise was coming from underneath so after going under for a look the prop bit that goes into diff is mangled |
Sat Sep 12 2015 9:58pm |
The good news is, it is an easy fix.
Sat Sep 12 2015 10:01pm |
Cheers Mike so do you think i should just buy a new prop and put it on then |
Sat Sep 12 2015 10:07pm |
It sounds like it needs a new prop regardless, but just give it a look over to see if ere are any indications of why it failed... |
Sat Sep 12 2015 10:19pm |
Fri Sep 18 2015 8:25am |
Trust it to be my sport, just my kind of luck |
Fri Sep 18 2015 12:16pm |
Oooo that's a bit nasty! Bodsys Brake Bible
Mon Sep 21 2015 11:06am |
Mon Sep 21 2015 9:16pm |
That was one diff Ray
Mon Sep 21 2015 9:23pm |
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 204 |
OOOH! I love jigsaws |
Mon Sep 21 2015 9:25pm |
Thanks for fixing the problem so quick Mike, think I will have to stay offshore to avoid the wife after she had to raid her piggy bank lol, I cant understand why such a nice vehicle with a long 4x4 history can do this to a diff when it only has 74 K on the clock glad I was not in the Sahara |
Tue Sep 22 2015 7:18pm |
It looks as ough someone has had something to do with the diff at some point in its life
Tue Sep 22 2015 9:09pm |
