![]() | Home > Technical > Restricted Performance |
| Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 242
Well only owned the car for two weeks and only the second time I have been out for a longish run.
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4517
The 3.0 has known issues with the turbo changeover valve (I forget it's correct name |
Thank you for the reply and sorry about my ignorance but what is TSB ?
Well the garage phoned today and say will deliver it back tomorrow. |
It's possible. If he DPF system can not be monitored correctly, the car will shut itself down to minimise emissions/soot etc going down the exhaust, to prevent the DPF from blocking up
Thank you Disco-Mikey
I used to run a Toyota Auris (2.2 T180 D-CAT) with a DPF, and I was told to use a decent quality fuel, and I wouldn't have any issues.
They may have been done, I just presumed that if they showed up it was because they had not, but I don't know.
| Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327
Just had mine in at the dealers to investigate Restricted Performance problems when covering long distances when the car has been cruising for about 2 hours.
Finger crossed |
Well I was right not to be convinced by the dealer's diagnosis. |
