Home > General > Thinking of Buying RRS
Sniffer
Hi
Just joined up as I am at the moment seriously considering RRS to replace my Discovery 2 V8
Had Land Rovers for about 3 years now and love them to bits but also hate the bleeders sometimes too, they are definitely a challenge at times thats for sure
Anyways, budget gets me an HSE 2.7 V6 with about 100K on the clock 06 or maybe 07 reg but I am really struggling handing over Ł12-Ł13k for a car with 100k on the clock but I suppose I'll get over that!
So, just a couple of questions from you well weathered RRS owners
    1 What is the extra button on the top left of the steering wheel? (most don't have it)
    2 How important would a warranty be?
    3 Why do all the rear passenger locks appear to be U/S?
Been on forums with my last 4 cars so really looking forward to seeing how this one works for me
Hope to be the proud owner real soon and will get some pictures up once I have one
Thanks in advance for all your help
Sniffer - aka Paul
Post #472236 Sun Sep 06 2015 8:43pm
TheWojtek
1. Radar cruise control. You can live without that (and most 2.7's doesn't have this option in any spec anyway)
2. A 2.7 TDV6 has two main problems: first, the oil pump in the early models was faulty by design. LR has changed this pump and it should've been changed by an owner while doing the cambelt, however a failure of this pump is catastrophical and the only way to check if the pump has been actually changed to the newer design, is to do the whole cambelt procedure anyway. Second: the main bearings are extremely sensitive to any change in lubrication - be it efficiency of the oil and pump. So yes, a warranty would be your good friend once you get a 2.7. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #472269 Sun Sep 06 2015 10:31pm
Sniffer
Many thanks for the reply fella, it's appreciated
You're probably right about the adaptive cruise control and I think definitely correct about a warranty, thnk I may of known that answer before I asked LOL
Just another quick question please, do they all come with towing electrics and the fitting for the detachable tow bar or not?
Thanks again
Paul
Post #472331 Mon Sep 07 2015 7:14pm
TheWojtek
The fitting is stock I believe (all cars I've seen had it), so I assume most cars would be delivered with the actual hook in the trunk. Mine didn't (and the hook goes for around 200 quid, IIRC :/ ). I don't know about the electrics, but it would seem implausible to outfit the car with the hardware and not the electrics. It is possible that the actual connection, wires and power outlet, was a dealer-installed accessory but you'd have to ask someone who took delivery of a brand new RRS back in the time Wink Regards etc.,
Wojtek
Post #472335 Mon Sep 07 2015 8:04pm
Frax
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
I had a 2.7 and it was supplied second hand with no tow ball but there was a slot in the tool kit for one.
I did get one from the dealer but think it came from another Range Rover.
When I removed the cover there was no tow electrics so had to fit them my self.
If you are going to look at one I would remove the cover and have a look and check the tool kit to see if the tow ball is there. Lot of Landcruisers now sold
Audi TT 240 Sport now sold for.
RRS 2.7 HSE Now sold for.
RRS Autoibiography 2012
Defender 300tdi 90
Post #472340 Mon Sep 07 2015 8:53pm
Sniffer
Thanks for the tips chaps, going to take a peep at a couple this weekend so will heed your good advice
Another cheeky question, V6 or V8?
Paul
Post #472791 Fri Sep 11 2015 7:25pm
Frax
Depends if you want speed and thirst or a bit slower and better fuel economy.
There is a lot to consider and would have a good read about both before you make up your mind. Lot of Landcruisers now sold
Defender 300tdi 90
Post #472795 Fri Sep 11 2015 7:41pm
