Home > My Range Rover Sport > MY 2009 RRS AUTOBIOGRAPHY CONVERSION
Page 2 of 3 <123>
TheWojtek
Running boards be gone.
As much as the 22" look Geneva-car-show-class, they somehow are not my cup of tea, however YMMV. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #472264 Sun Sep 06 2015 10:24pm
D6EML
Scotland 2009 Range Rover Sport TDV8 HSE Stornoway Grey
Doesn't quite work like that , when you lower the normal ride height by say 20mm all other levels are lowered by 20mm 👍
Post #472266 Sun Sep 06 2015 10:27pm
D6EML
Each to there own 👍
Post #472267 Sun Sep 06 2015 10:29pm
jammin
England 2007 Range Rover Sport TDV6 HSE Arctic Frost
cheers understand so if i lower ride height all others will follow by same amount, cheers for explaining
jay
Post #472268 Sun Sep 06 2015 10:30pm
D6EML
That's correct jay 👍
Post #472287 Mon Sep 07 2015 8:02am
SRE
Spain
Looks nice, well done. However, you need the later rear lamps, plus I assume the lowered ride height is OK for tootling around, but what happens when the suspension automatically drops 20mm at high speed Question Embarassed Question I bet its interesting, time for clean underpants Whistle In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #472299 Mon Sep 07 2015 10:05am
D6EML
Thanks mate , yeah the rear lights would really set the back end off nicely 👍
Being honest the ride isn't much different at -26 mm
And If I'm doing some motorway journeys il probably revert to factory height .
Dean
Post #472301 Mon Sep 07 2015 10:11am
m17kyu
2007 Range Rover Sport TDV8 HSE Lux Java Black
Really like this, If you plan to change your rear lights to LED I would be interested for my HST conversion
Post #472308 Mon Sep 07 2015 11:50am
D6EML
M17kyu - sure mate 👍 il let you know when I sort some lights out
Dean
Post #472310 Mon Sep 07 2015 12:52pm
mnk
Dean
Am I right in thinking that as you are using your pre-facelift head lights the front body kit is not genuine LR parts.
BTW car looks fab.
Post #472324 Mon Sep 07 2015 5:32pm
Tim in Scotland
Can I ask what hub changes you had to make to get the RRS2 22" wheels to fit? I want to go the other way and fit a set of Goodyear Mud Terrain Tyres on Disco3 wheels.......... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #472326 Mon Sep 07 2015 6:06pm
RRS2 wheels bolt straight on a RRS1 with no changes, the wheels just have a slightly different offset. RRS1 53mm and RRS2 49mm.
Post #472328 Mon Sep 07 2015 6:42pm
D6EML
Mnk - yes the front bumper is not genuine LR .
Tim in Scotland - I'm not aware of any hub alterations
Dean
Post #472337 Mon Sep 07 2015 8:24pm
Tim in Scotland
Thanks guys 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #472339 Mon Sep 07 2015 8:34pm
SRE
Spain
D6EML -- A simple question for you to think about
When a car is permanently lowered does this not add a stress to the suspension bushes, stresses that the car was not designed for, especially when the car is an access height. I thought that the suspension bush had a specified amount of twist in it, basically acting as a spring.
I am sure one of the tech guys Disco-Mikey or similar will be along to clarify, plus I understood that the suspension had to be torqued up at specified position. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #472385 Tue Sep 08 2015 10:49am
Page 2 of 3 <123>
