Home > Wheels & Tyres > Best rim size?
foxtrotzulu
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
Best rim size?
Hello everyone. Just joined and this is my first post.
I am just in the process of buying a RRS and narrowing down my various options to find a 2nd hand vehicle that fits my needs. I'll be looking for a 2010 or maybe 2011 vehicle and I see that most of them come with 20" rims and a few have 19" rims. I am not overly fussed about the looks (don't like the low profile look or ride), I will be using the car off road (muddy fields of Berkshire) and may need to fit winter tyres and/or snow chains at some stage.
Am I right in thinking that 19" rims are easier to find winter or off-road tyres for? Do chains fit OK on 20"?
If my suspicions are correct then I'd probably plump for 19", but they seem a lot harder to find than 20". I am right in thinking that the 19 and 20 are the 'normal' sizes aren't I?
Any advice gratefully received.
Post #472021 Fri Sep 04 2015 6:31pm
Disco_Mikey
Cooper LTZ are readily available in 20" Thumbs Up
Post #472022 Fri Sep 04 2015 6:36pm
foxtrotzulu
I'm not sure the Coopers are winter rated are they?
My question was more general - Is it easier to get 'softroad' winter tyres for 19" than 20"?
Is it easier to get chains on 19" than 20"?
Post #472024 Fri Sep 04 2015 6:51pm
TheWojtek
Winter tires - 19" make more sense (more sidewall) and there's more of them as well.
Chains - no difference, as the overall diameter of the tire doesn't drastically change if you stick to the tire size chart from the B-pillar. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #472039 Fri Sep 04 2015 7:51pm
You can fit 255/55/19 to a RRS. It's the Discovery size tyre. That brings in the Goodyear Duratrac which is marked as a winter tyre in all other sizes (Land Rover apparently didn't want it so marked on the Disco - no idea why).
You can get the General Grabber AT in 255/55/19, 255/50/19 (not sure how common that size is at the tyre dealers though) and 275/40/20. The AT is good all round tyre being pretty decent off road and in snow (not winter rated though) and good on road. Gets noisy as it wears.
The Cooper LTZ is available on 19 and 20 inch rims. Similar to the AT and not winter marked.
You can get winter tyres in both 19 and 20 inch.
I run my TDV8 on 255/55/19 Grabber AT. I have a set of 19 inch rims that I'm thinking of mounting Duratrac on
Obviously if you fit other than 255/50/19 or 275/40/20 you should check with your insurer as those are the approved sizes. Thumbs Up . 2012 SDV6 - it's missing a couple of cylinders
Post #472040 Fri Sep 04 2015 7:57pm
foxtrotzulu
Thank you. Very helpful.
Post #472089 Sat Sep 05 2015 8:51am
Lost for Words
Stick with 19, IMO. Pirelli ATRs come very highly recommended (excellent on and off road) - lots of info on the D3 site. Thumbs Up Visiting from DISCO3.CO.UK
Post #472094 Sat Sep 05 2015 9:17am
ATR is an excellent tyre but not so good in muddy conditions as the Grabber AT. 2012 SDV6 - it's missing a couple of cylinders
Post #472131 Sat Sep 05 2015 5:44pm
riverblanche
As above ^
I have took my 275 40 20 off (keeping for best Laughing ) and fitted 255 55 19 at's and noted less white lining Whistle
possible softer ride! But not sure if that's just my mind playing tricks!
Come the winter it's vredestiens this time 255 50 19
Post #472630 Wed Sep 09 2015 10:37pm
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
Stick with 19"/20" . Do not go 22" as they have much less sidewall and tend to buckle and/or crack.
Post #474411 Sun Sep 27 2015 1:35am
muddywheels
Milk Float Man
I ran 20" in summer and 19" in winter and preferred the 19" for comfort
19" also better for offroad and less risk of kerb or pothole damage Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #474421 Sun Sep 27 2015 8:31am
