![]() | Home > General > Can I be in your gang? |
Jerseybloke Member Since: 30 Aug 2015 Location: Jersey Posts: 14 ![]() ![]() |
Hi all,
You have to pay a 5% import tax, plus an emissions duty which I think is about £300 and the cost of the ferry, which is about £300 but also have to factor in the cost of getting over to the mainland to test drive cars which potentially you don't buy.
The TDV6 is not exactly underpowered (and it all depends on what you're used to, of course) but, as standard, it's never going to be as quick as the TDV8. A remap would help greatly, and if you want to go further, you can add an uprated intercooler and de-cat pipe (as I have |
I ran a 2.7 with a BAS (Pete Bell) remap for a few years, Pete's remap is what the Sport should have had to start with, it makes a big improvement to the drivability of the car. |
Thanks for the replies guys and thanks Lost for Words for the offer, much appreciated.
caperbility Member Since: 14 Jan 2010 Location: landscaping the world Posts: 221 ![]() ![]() ![]() |
Make sure it has fsh |
Make sure it has a bullet proof warranty. ![]() |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 748 ![]() ![]() ![]() |
Pray your TDV6 had the oil pump replaced with the newer design. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1942 ![]() ![]() ![]() |
If your driving is only Jersey 40 mph and some Continental Motorway driving, then I think the TDV6 will be fine for you. I used to drive semi urban (40mph) then longer freeway runs and I was happy with the 2.7 TDV6, it's a smooth and quiet engine for a motorway cruise. |
I'll try to go through some common/major issues. Bear in mind, a lot/most of these are mileage dependant. In no particular order:
Lost for Words
....aaaaand that's what my RRS has developed throughout the weekend. Any hints on how to trace the error to the left or right seat and the failing circuit? Switching the pass. airbag with the key makes no difference. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE Last edited by TheWojtek on Mon Aug 31 2015 9:25pm. Edited 1 time in total |
Best thing is to have a poke about under the seats, checking for any dodgy connections or stretched wires. In particular, check the wire down the side of the seat(s) to the seatbelt pre-tensioner. |
Wow, thanks for all the info.
