Home > Technical > Command shift.
Tyrefitter
Command shift.
Hi,I noticed tonite that my command shift will gear down but not gear up when I have side lights or headlights on,as soon as I switch them off it works fine,as anyone had this problem before I take it back to stealers for a warranty fix.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #471139 Wed Aug 26 2015 7:19pm
DrRob
In D or S ?
I did read somewhere only to use in S.... * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #471141 Wed Aug 26 2015 7:45pm
Tyrefitter
In both DrRob,,command shift works in D & S unless lights are on then I can only gear down.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #471143 Wed Aug 26 2015 7:50pm
jeffhunt
is that using the flappy paddles behind the steering wheel.?
If so, I had exactly the same problem, it turned out to be a dry joint on one of the connections.
Removed the paddle shifters (1 screw) disconnected the plug, blew out with an air duster, added some WD 40, works a treat now. Can be done without taking the steering wheel off.
Hope this fixes it.....
Post #471165 Thu Aug 27 2015 5:44am
Tyrefitter
Tks Jeff,,ill try that later,,its just weird they work fine without lights on but don't with lights on.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #471168 Thu Aug 27 2015 7:51am
Lost for Words
Thinking this could be a case of the same issue that occurs with the older vehicles. On the older vehicles, there's a wiring splice under the front of the passenger sill that corrodes (purple/blue wire), causing loss of sport and command shift when the sidelights are on. Would be interesting to hear if this fault happens to the 8 speed. Idea Thumbs Up
http://www.disco3.co.uk/forum/topic79211.html
Arrow Visiting from DISCO3.CO.UK
Post #471169 Thu Aug 27 2015 8:11am
Tyrefitter
ive pulled it into my workshop to check it out now,,i will keep you all informed on progress.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #471186 Thu Aug 27 2015 1:00pm
Tyrefitter
Had the paddle off & that doesn't make any difference.....so next step is wiring.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #471200 Thu Aug 27 2015 3:13pm
Tyrefitter
Well ive fixed it,,even though it was the right hand paddle to gear up it was the conection on the left paddle that needed cleaning.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #471202 Thu Aug 27 2015 3:31pm
jeffhunt
Cheap fix. Did you put WD40 in it? It kept recurring for me until I put a good squirt in.
Post #471203 Thu Aug 27 2015 3:50pm
Tyrefitter
I used some clutch & brake cleaner on the left one.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #471206 Thu Aug 27 2015 4:50pm
