Home > In Car Electronics > Heated Rear Screen only working on bottom
savi18
New Zealand
Hi All, Only had this 2009 RRS for 2 weeks and have multitude of faults with it, this post is to do with the rear screen, it was iced up this morning so used the heated rear screen button for the first time, and only the bottom 2 heater wires heated up, rest of screen frozen solid, if there is a break further up the screen is there a repair kit to fix. Cheers
Post #470162 Wed Aug 12 2015 10:13am
garrycol
Australia
Does the same happen if you use the "program" button instread - I find it works best.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #470165 Wed Aug 12 2015 11:29am
savi18
New Zealand
It its frozen again 2morro will try the prog button. If not it's out with the test meter this weekend. Cheers
Post #470170 Wed Aug 12 2015 12:13pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
I had this exact problem on mine, if you look closely the elements will be a different colour further up the screen, I suspect on mine someone had loaded something in the boot that rubbed against the elements damaging them.
If they are damaged there is no effective way to repair them, in the end my insurance company paid for a replacement on the basis it wasnt safe to drive, so I just paid the excess.
Post #470171 Wed Aug 12 2015 12:26pm
savi18
New Zealand
Are these rear screens laminated same as front or do they go into thousand of pieces when cracked/smashed, Cheers
Post #470763 Thu Aug 20 2015 7:14am
Paddi
Before you go smashing the rear screen with a hammer you might want to check the battery condition as low charge results in the battery management system not permitting operation of the rear screen heater. Another frequent problems is a corroded connector in the wiring under the spoiler - use the search function to find a detailed description of DIY fix. 2008 MY Java Black TDV8 HSE
Post #470778 Thu Aug 20 2015 9:13am
savi18
New Zealand
No Intension of smashing the glass, the rear glass will be changed free of charge by insurance company as this could be a safety issue I think, its just when they take it out what will happen, Cheers
Post #470782 Thu Aug 20 2015 9:28am
