Home > General > Activating Different options, TPMS & Dual View
a3hy
United Kingdom 2012 Range Rover Sport SDV6 HSE Fuji White
I have a 2012 sport without TPMS and Dual view tv
I have changed the wheels to 21" genuine land rover wheels and they came with the TPMS valves in. Is it just a case of activating the system at the dealers for this to work or is a lot more involved, I'm not that bothered about it but whilst the wheels have the valves it would have been nice if i could get it to work on the info display (wheels are actually off a 2014 sport)
Also same question for dual view tv, is this an activation or a whole new head unit.
Thanks
Post #469965 Sun Aug 09 2015 7:37pm
I have both Dual View and TPMS, I think the Dual View would be a complete Head Unit and some wiring as it was a Optional Extra when new and there is a Dual View switch where the Set Up switch normally is on the Dash.
The TPMS which was a option as well and is not really that good in my own personal experience of it, it only Activates when Tyre Pressure drops to 20psi. which is o.k. I suppose and you are actually driving and it goes down but I would have thought you might know you have a flat tyre by then. It is also prone to Flashing up when the Ambient Air Temp. is high and there is nothing wrong with the Tyres or Sensors.
I also fitted 21" rims from a 2015 Car and changed the Sensors as they are different Part Numbers for the RRS1 to the RRS2' I'm not saying they would not work because I don't know but you may have to fit the later RRS2 Receiver assuming it would fit.
Post #469973 Sun Aug 09 2015 8:15pm
a3hy
ah okay, thought it might be the case with the dual view.
Re the TPMS, if thats the case i don't think i will bother, might be worth it if it showed live tyre pressures but if it only warns when really low then its not for me as i do check tyres very regularly... bit OTT where tyres are concerned.
Thanks for info.
Post #469983 Sun Aug 09 2015 9:26pm
