Home > General > HELP hand brake jammed on can't move the car!!
Lewis
United Kingdom 2008 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Hi chaps got a bit of a problem my hand brake is not releasing I can hear the actuator making a noise but it won't release, I have tried the manual release under the centre console but no joy! This is especially bad timing as I need to go and pick up my missus from hospital as our first baby has just been born and all the gear is in the car! is there any method of getting the hand brake to release? Many thanks in advance?
Post #469444 Tue Aug 04 2015 6:23pm
Lost for Words
You have to pull the emergency release VERY hard. Pull it until you think something's going to break, then pull it a bit more - it really can take that much! Thumbs Up
Congratulations also. Smile Visiting from DISCO3.CO.UK
Post #469446 Tue Aug 04 2015 6:31pm
Lewis
Ok many thanks for the swift reply! It felt like I was just pulling slack on the spring when I pulled it will try a bit of force thanks again!!
Post #469451 Tue Aug 04 2015 6:39pm
Lost for Words
Yep, it takes a lot more than that, hence the need to use the jack handle or similar. Thumbs Up Visiting from DISCO3.CO.UK
Post #469454 Tue Aug 04 2015 6:47pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
If you do manage to release the cable, you will need to re-latch the cable inside the Electronic Park Brake module. Disco Mikey done a excellent write up on how to unjam and re-latch.
I had this issue but most importantly you will need to check your module and brake shoes to make sure they are all ok.
Bodsey's Brake bible will help you out Thumbs Up
Post #469455 Tue Aug 04 2015 6:48pm
Disco_Mikey
I have bent a few Jack handles pulling the release. They can be very, very tight Shocked
Post #469461 Tue Aug 04 2015 7:51pm
Lewis
Thanks for the help guys, I tried to pull the release by putting a screw driver through the loop but no joy I'll try the jack handle method tomorrow is it possible to break the release by pulling too hard? Also when I press the button I can hear the motor turning be it doesn't sound like it's moving anything just free spinning, is there like a plastic cog wheel that turns a worm gear or something?
Many thanks again!
Post #469522 Tue Aug 04 2015 11:46pm
Lost for Words
The prescribed method is to put the supplied screwdriver through the hole in the jack handle. It has been known for some release cables to snap. Thumbs Up
That's the basics of it, yes. Wink
Sometimes it can be re-latched on re-application of the EPB or with a diagnostic tool. Thumbs Up Visiting from DISCO3.CO.UK
Post #469542 Wed Aug 05 2015 9:29am
Lewis
Right then no joy on pulling the release with the jack handle. Is there any way I can't get the car to the garage to get fixed apart from a recovery truck? could be the last straw nothing but problems with this car so far! Many thanks for your help👌
Post #469614 Wed Aug 05 2015 8:21pm
DrRob
Will this work?
http://www.disco3.co.uk/wiki/EPB_Emergency_Release * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #469617 Wed Aug 05 2015 8:42pm
Disco_Mikey
Pull harder Whistle
In all seriousness, I have had them so tight, I have had to straddle the centre console and physically bent the jack handle, they have been that tight.
If you drag it onto the back of a recovery truck, you risk damaging a whole lot more than the EPB module...
Post #469619 Wed Aug 05 2015 8:49pm
nigel52
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Well no one could release my EBR and they had no option but physically drag my RRS on to the back of a very large break down truck . This took three hours near La Rochelle. See my post stuck in France.
Don't you just love them!!
Big Cry
Post #469620 Wed Aug 05 2015 8:56pm
Lewis
DrRob wrote:
Will this work?
Thanks Rob but no it doesn't work I think I'll need to rig up my engine hoist to pull it
Post #469633 Wed Aug 05 2015 9:43pm
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hardly use the thing on mine, just shove it into P Very Happy But I do admit to flicking it up and down a few times just to keep it going Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #469636 Wed Aug 05 2015 9:49pm
Lewis
Still no joy get release to work bent the jack handle and smacked myself in the nose, I've booked into a specialist up here in Aberdeen (who it's just been to 2 weeks ago for a service) they suggested I will need a new module what sort of bill would I be looking at to get this done? Cheers.
Post #469953 Sun Aug 09 2015 7:05pm
