| RRSPORT.CO.UK | ||
|  | Home > Faults & Fixes > Constant beep when select reverse |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      | Hi,,is their anything obscuring a rear sensor.?
|  Sat Jul 25 2015 8:40am |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796    | Common fault   | ||
|  Sat Jul 25 2015 9:29am |
| Stacky-hst Member Since: 01 Jul 2015 Location: Bristol Posts: 13    | Hey guys I haven't taken a bumper off a Range Rover before but other cars is it easy ? Is the fix doable myself or Land Rover Jobby ? Thanks And no nothing's in the way of the sensor | ||
|  Sat Jul 25 2015 11:25am |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | It's relatively simple. A few screws below the bumper, a couple in the wheel arch from memory. Lever the ends out to pop it off. Easier with help but ok alone. The wiring can be fixed either with a suitable butt connector or by soldering. Ensure whatever you do is protected from water ingress. I did a temporary repair on mine earlier this year and it's been fine until some recent wet weather running caused the odd error. I bought a replacement loom for about £50 and will, at some point, fit that to make a permanent repair.
|  Sat Jul 25 2015 2:37pm |
| darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442      |
 Im presuming that you can't tell if it is an eroded cable or the sensor itself until you get the rear bumper off? I have an intermittent failure on mine. Weather conditions etc make no difference, dry, wet, hot, cold etc. They can work/stop working on the same journey, even on the same reversing operation. 2006 HSE for Sale - £7,499 (Manchester) http://www.rrsport.co.uk/forum/topic46383.html | ||
|  Tue Aug 04 2015 5:36pm |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | First pass would be to read the fault codes or look at the live values to determine which one is faulty. Bodsys Brake Bible
|  Tue Aug 04 2015 5:39pm |
| darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442      | When I've previously had my fault codes checked there wasn't anything relating to it? im presuming that you would only get a fault code when they are failing?
|  Tue Aug 04 2015 6:22pm |
| Posting Rules
 either eroded electrical cable or parking sensor failed - how are you at taking bumpers off
