| RRSPORT.CO.UK | ||
|  | Home > Technical > MY12 RRS cutting out losing all power |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2026    | Does it have the LR warranty? Use it   | ||
|  Fri Jul 17 2015 7:38am |
| lost Member Since: 17 Jul 2015 Location: Eveywhere Posts: 9      | Has 3yr warranty Dr Rob but not 100% sure off of who as the OH bought the car. They are away and haven't said to them there are issues.
|  Sun Jul 19 2015 11:36am |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | It could be one of the most common problems:
|  Sun Jul 19 2015 3:35pm |
| lost Member Since: 17 Jul 2015 Location: Eveywhere Posts: 9      | Thanks Paddi. It just cut out again there now. Just went to local diy shop and left there and then stopped at traffic light it cut out again.
|  Sun Jul 19 2015 3:59pm |
| lost Member Since: 17 Jul 2015 Location: Eveywhere Posts: 9      | Faulty brake pedal switch (order on eBay or from Duckworths and replace - it is a 5 minute job)
|  Sun Jul 19 2015 5:45pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Hi Lost,
|  Sun Jul 19 2015 6:33pm |
| lost Member Since: 17 Jul 2015 Location: Eveywhere Posts: 9      | Thanks Paddi | ||
|  Sun Jul 19 2015 6:43pm |
| lost Member Since: 17 Jul 2015 Location: Eveywhere Posts: 9      | Anyway just a quick update. I was away on hols and just back so sent the car to the dealer yesterday. They came back that they think they know what's wrong and its a camshaft sensor fault or wire leading to it. Anyway they want to keep my car to make sure they have fixed the issue. If it shows up again they said they will have to replace the sensor. | ||
|  Fri Jul 31 2015 5:19pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Be sure to update again when you get it back please.
|  Mon Aug 03 2015 1:09pm |
| lost Member Since: 17 Jul 2015 Location: Eveywhere Posts: 9      | I am thinking the same Paddi. They have the car since Thursday. There was a wire lose I was told Thursday. Friday it was to do with the sensor and they wanted to keep it to see if the fault reappears and that they wanted to hold onto the until today or tomorrow. As I was away today I told hem I would call them tomorrow to see what the story was. Fingers crossed I twill get it back tomorrow FIXED  | ||
|  Mon Aug 03 2015 4:19pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Looking at the workshop manual for the TDV6 - says to replace the camshaft position sensor (CMP) it is necessary only to remove the LH EGR valve to gain access to the sensor. So doesn't sound like a huge job (an hour?). Sensors usually seem to cost between £40 and £150.
|  Tue Aug 04 2015 12:07pm |
| lost Member Since: 17 Jul 2015 Location: Eveywhere Posts: 9      | Just a quick update. They are replacing the sensor now as the quick fix has not worked.. Waiting for part to come in and check that car is fine before we get it back. | ||
|  Tue Aug 04 2015 7:15pm |
| lost Member Since: 17 Jul 2015 Location: Eveywhere Posts: 9      | Just another update. It seems I misunderstood over the phone what the fault is and its actually a Crankshaft Sensor not a camshaft sensor that has gone. So it seems that the gearbox has to be taken out to replace this and its about a 7 hour job.  Part only arrived in today. They said  they are hoping to start tomorrow as they have a couple of mechanics in and if not Monday.   | ||
|  Fri Aug 07 2015 3:59pm |
| Posting Rules
