Home > Technical > Gearbox adaptions
Radioham 49
United Kingdom 2005 Range Rover Sport TDV6 HSE Stornoway Grey
Gearbox adaptions
i have a 55 plate 2.7 Sport that had a gearbox judder when changing from 3rd to 4 th gear.. I have reset the gearbox adaptions but the gearbox changes are very juddery & the gearbox goes into limp mode every couple of miles showing F in the display. This is reset when the ignition is re cycled. Can you tell me if the gearbox ECU requires re flashing or will the gearbox changes improve with use?
Post #468469 Fri Jul 24 2015 8:11pm
DrRob
Has it had a proper oil flush and the codes read? * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #468470 Fri Jul 24 2015 8:29pm
The gearbox adaptions allow the gearbox to accommodate its own internal wear as well as the driver's style. Clearing the adaptions will set it back to the settings it had as a wear free unit. This is presumably why yours is now throwing errors because it think things are out of tolerance. 2012 SDV6 - it's missing a couple of cylinders
Post #468472 Fri Jul 24 2015 8:45pm
Radioham 49
Thank you for your prompt reply.
Present is 1 transmission fault
P0783-64 ( ED) 3-4shift. Algorithm based failure- Signal plausibility failure.
My son in law had the car previous &I do not remember him having any flushes/oil changes to the gearbox oil.
The car has had an occasional confused gear changes previous to adaption reset, this has resulted in the limp home in 3rd gear.
The fault code was " Incorrect gear ratio" This fault was reset by recycling ignition.
Post #468475 Fri Jul 24 2015 8:57pm
Radioham 49
RRSTDV8, thanks for your help. Do you know if the gearbox changes will improve with time or have I messed it completely ?
Post #468478 Fri Jul 24 2015 9:08pm
DrRob
A flush is recommended for all gearboxes with a bit of age and mileage. * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #468481 Fri Jul 24 2015 9:32pm
Disco_Mikey
You may have killed your gearbox...
How many miles are on the car?
Adaptions should only be reset, if you know EXACTLY what you are doing, and why you are doing it...
Post #468482 Fri Jul 24 2015 9:40pm
No idea, sadly. It might be worth speaking to someone like Bristol Transmissions who have a good reputation with this gearbox.
If I was putting a pound on it, I'd go with a strip/refurb of the 'box being required. 2012 SDV6 - it's missing a couple of cylinders
Post #468485 Fri Jul 24 2015 10:01pm
Radioham 49
Car has done 123 k miles. I wish I had left the adaption reset alone, too late now
Post #468490 Fri Jul 24 2015 10:40pm
Radioham 49
Can you tell me if Bristol Transmissions are the best or is there somebody as good that is closer to Kent?
I realise that I have to spend out to have the gearbox fixed , I don't want to waste money on a sub standard fix.
Post #468550 Sat Jul 25 2015 8:41pm
Disco_Mikey
You need to reset the adaptions once more, then drive the car very gently for the next 2-300 miles.
There may be an underlying issue with the gearbox, and the above may not help, but it will give the gearbox a fighting chance
If it doesn't help, then it's likely the clutch plates have become damaged , and a box refurb is needed
Post #468554 Sat Jul 25 2015 8:58pm
Radioham 49
Disco-Mikey many thanks for your help. I will reset again tomorrow & drive it as you recommended.
Post #468557 Sat Jul 25 2015 9:10pm
Radioham 49
Adaptions reset again as suggested.Able to drive the car in command shift. Have to back off the throttle when shifting into 4th gear (original fault). Have provisionally booked car into Bristol Transmissions & will travel down overnight when less traffic is about. Does anybody know if once 6th gear is selected will it stay there for the duration of the journey if the road speed is high enough.
Post #468855 Tue Jul 28 2015 6:49pm
If you can keep it at a reasonable speed then it should stay in 6th. It'll change down even in Command Shift but not until about 50mph (a guesstimate from hazy memory). On a fast A-road or m-way it should be stay in 6th. 2012 SDV6 - it's missing a couple of cylinders
Post #468861 Tue Jul 28 2015 8:32pm
Radioham 49
Many thanks for your help.
Post #468871 Tue Jul 28 2015 10:14pm
