![]() | Home > General > Water in rear tyres |
Marvik125 Member Since: 02 Jul 2015 Location: West Midlands Posts: 139 ![]() ![]() ![]() |
nitrogen filled sealed tyres |
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 ![]() ![]() ![]() |
I had the same problem in the fronts. I think it's an issue with the Pirelli tyres. I suspect the answer is as above. |
braveheart20 Member Since: 04 Apr 2012 Location: leven Posts: 22 ![]() ![]() ![]() |
Hi there I had the same issue went back to land rover due to the excessive vibration. Transpires it was water inside one of the rear tyres land rover dealer tried to charge me for the work.
Moog2014 Member Since: 13 Jan 2014 Location: East mids Posts: 12 ![]() ![]() ![]() |
Have a look here :
Silvermercf1 Member Since: 24 Jul 2015 Location: Nottingham Posts: 6 ![]() ![]() ![]() |
Thanks for the feed back.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9129 ![]() ![]() ![]() |
Do you pressure wash your car? Perhaps it's done when serviced? Get a pressure washer jet up against the beading and I bet you'd force some water in. 2012 SDV6 - it's missing a couple of cylinders
CRC@LandRover Member Since: 20 Jul 2012 Location: Coventry, West Midlands Posts: 213 ![]() ![]() |
Hi Silvermercf1
PWW Member Since: 08 Feb 2013 Location: Kent Posts: 17 ![]() ![]() ![]() |
Had the same issue.
